Bad fuel or spark plugs or what? Car wont start!
Old Oct 22, 2013 | 08:31 AM
NinjaJDMB18c's Avatar
Default Bad fuel or spark plugs or what? Car wont start!
Car:
1994 Acura Integra LS w/ swapped 1998 JDM B18c Type R motor.
After filling up gas one day I attempted to start car and the followjng occured:
- Car would start then start rumbling and and struggle to stay on. It would then cut off. This occured 4 more times. Even if I would put into gear and floor pedal the rpms wouldnt go up but continue to struggle to stay running. Finally after the 5th time to corrected itself and stayed running.
Current Issue:
- Tried to start car this morning and car is turning ovet but wont catch and start running. Also I dont believe I heard the fuel pump kick on when I turned key 3/4th of the way.
Now there is another possibility. I just bought this car from a private seller and he told me he changed the spark plugs before selling it to me. Problem is when I called him about the car not staying running the first time he said he wasn't sure of he gapped them correctly (go figure).
So anyone have any thoughts on what it could be? Also if it is fuel pump would I be buying a fuel pump for a 94 Integra LS or 98 Integra Type R. Let me know if more info is needed. Thanks!
Sent from my DROID X2 using Tapatalk 2
Old Oct 30, 2013 | 07:11 PM
MiraiZ's Avatar
Default Re: Bad fuel or spark plugs or what? Car wont start!
Need more info, video...What do the spark plugs look like? Have you check the dizzy cap? Have you check the cables?
Three components needed to start your car:
-Air
-Fuel
-Spark
Make sure that the engine is getting sufficient amount of each
Old Oct 30, 2013 | 07:36 PM
Ended up being main relay switch for fuel pump /fuel system. but i do appreciate your help and advise.
NinjaJDMB18c
Oct 26, 2013 01:55 PM
NinjaJDMB18c
Oct 23, 2013 08:25 AM
vinuneuro
Oct 12, 2006 05:44 AM
ICeDoUt
Aug 18, 2005 01:38 PM
93egsi
11
Jun 18, 2004 05:37 AM
