h22 swap into 97 accord no spark
I swapped an h22 internal ignition coil into a 97 honda accord. The car cranks but no spark. There is fuel. i searched online and converted the external coil to internal coil. I do have voltage at the internal coil. coil resistance in spec. Ive swapped the ignitor with a good one.
I moved the 4 wires for the crank sensor(s) to the internal distributor plug. I do have continuity from the obd2 plug to each wire on the distributor.
I used a obd2 to obd1 conversion harness.
Am i forgetting something? why dont I have spark? I have good compression
DigitalPunk
Jul 27, 2013 12:53 PM
