aem gauge install
Old Oct 21, 2013 | 05:27 PM
ppiart's Avatar
Default aem gauge install
I know installing gauges has been covered many times. Basically I'm installing 5 digital aem gauges and would like to know if I can tie all of them to the power wire off the stereo harness or if i should tie into the fuse box will wiring all the gauges to one slot work ect.
Old Oct 21, 2013 | 08:03 PM
ppiart's Avatar
Default Re: aem gauge install
any and all replys will be appreciated
Old Oct 22, 2013 | 03:03 AM
Freemananana's Avatar
This is the running power correct? I wired 3 gauges to the radio input once upon a time and had no issues with it. Your best bet would be to wire the gauges to an empty slot of the Fuse Box that only turns on with the key. Then add a fuse, done.
Old Oct 22, 2013 | 03:35 AM
ppiart's Avatar
Ok that sounds simple enough thanks for your input
Old Oct 22, 2013 | 05:56 AM
Dark_Teg's Avatar
I love the AEM gauges. I went off the fuse box for juice. Here is my gauge set-up in the CRX. Boost/Wideband/Temp
Old Oct 22, 2013 | 06:04 AM
That's 22-whatevers- vacuum right? I like my manual boost/oil pressure gauges I have. They do the job.
Old Oct 22, 2013 | 06:30 AM
Dark_Teg's Avatar
I like the AEM's for reliability and they are easy to read at all times. I have them in my Mustang and Lightning as well
Takumi Fujiwara
Aug 8, 2006 12:53 PM
civichbcx
Nov 7, 2005 09:52 AM
XxslayerxX
Feb 1, 2004 08:33 PM
THE94GSR
Dec 7, 2003 08:28 AM
y2kintegra
Jul 29, 2002 01:05 AM
