Hidden Tech?
hey whats up HT! i saw this picture on facebook on 4Piston's page. Anyone have any experience with kind of piston and pin? i see some grooves on the side of the dome and in valve relief area and the pin looks weird(but cool) like it has a coating on it. Any experiences as to who has used this and how it contributes to power are more than welcome. ideas and opinions are also welcome!
share those power secrets :-)!
Oh alright. Wonder how much lighter the cranks are compared tk a stock one. K series has some nice stuff out there for it.I actually thought about WPC treatment on my pistons, even the sleeves of the block.
I hope some people chime in with some answers and experience with this kind of stuff.
Raised piston pin allow for a somewhat longer Rod, so that you can run a "decent" R/S ratio. Moreover allows for shorter pin since buttons are used in the slots wich can be from a lighter alloy thus making the piston substantially lighter. The pistons in the picture are also gass ported. The marks are of course CNC, Piston pin could be DLC coating.
CP, arias, je, etc offer gas ports on all custom pistons and to the OP they look like a custom crank custom rod with of course "stroker" style pistons that allow for better R/S ratio.
Sipes brothers had a ceramic looking coating on their pistons at one time and I know others have all sorts of coatings to transfer heat, and better sustain the piston material against harsher fuels also. I'm sure 4piston would be able to tell you most of the reasons behind anything in the picture.
Pin is probably gas nitrided which is really common nowadays because the surface is harder than the material which in and of itself contains several benefits of wear/friction/lubricity. Crank almost definitely is.
NHRA is mandating RPM limiters for pro stock next year . . . they are currently pushing 11,000RPM with 500" still using traditional style valve springs (which last a run or two).
I was hoping they would pick up pneumatic valve springs but it is what it is.
Some things must remain sacred
But I'll share what I'm willing.
-Crank is our Billet Winberg 106mm. 31 lbs, and polished.
-We don't use WPC, which is a texturing process to remove surface area.
-That isn't a coating on the piston
While making the most power is always a huge aspect of what we work on every day, We aren't exclusively concentrating on making power all the time. We put just as much effort into making the engine last a long time.
Follow our Facebook for more cool stuff. We post up things we are working on all the time.
But I'll share what I'm willing.-Crank is our Billet Winberg 106mm. 31 lbs, and polished.
Ok thanks 4 piston. Yea I almost thought it was a WPC treatment. That is a light crank considering its a 106mm and stock 89 is I think like 37 maybe more. That's great you guys focus on making power and longevity too!
caspers_hatch
Mar 20, 2005 07:52 PM
