Need Help with crx !!!!
well this is what has been going on with the crx it's completely dead, i put on the the battery terminals and nothing happens i had had it running before , but now there something wrong with it , the dash lights are not lighting up, i turn the key noting, if any one knows what this chould be let me know
Definitely sounds like a bad battery or your terminal connectors have gone bad. Make sure the wires aren't stripped out of the connectors if a new battery doesn't fix the issue.
i had it running last winter no prob,terminal connectors where changed with new ones, and also the battery is a newer battery i even had it charged , also i dont think wires are stripped out of the connectors, it had the wing nut style bolt on type... so there is not strip age .. so im kinda wondering if the battery might have something to do with this, im not sure it isnt new its like new.
Can you try jumping it from another car? If it gets power immediately that's a sign of at least a drained battery. If it can start and run without the cables attached that would also point to a drained/dead battery.
