Rack and Pinion Boot - Hose/Line from it
Old Oct 21, 2013 | 09:13 AM
WebDawg's Avatar
Default Rack and Pinion Boot - Hose/Line from it
91 Honda Accord Lx Auto
There is a hose/line that comes off one of the passenger side rack and pinion boot. It looks like a vacuum line.
What does it do? What is it for?
Old Oct 21, 2013 | 10:46 AM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Rack and Pinion Boot - Hose/Line from it
When turning left or right one bellow will compress as the tierod is pulled in via the rack and the other bellow will extend as the other tierod is pushed out. The tube is to balance air pressure between the bellows to prevent ballooning of the compressed bellows and a vacuum in the extended bellows. Without this bar a vent would be needed on each bellows, the tube allows air to ventilate from left to right while keeping the system closed.
Old Oct 23, 2013 | 11:32 PM
WebDawg's Avatar
Thanks for the reply.
ITS_Dunn
Honda CR-V & Element
Oct 29, 2015 07:54 AM
90Acura
Jul 7, 2013 07:12 PM
smeltjr
Aug 17, 2008 10:09 PM
