90 Honda Civic Si temp gauge dropping while driving
Old Oct 20, 2013 | 10:06 PM
mouab18c1's Avatar
Icon2 90 Honda Civic Si temp gauge dropping while driving
My Honda Civic will warm up to normal operating temps if it's just sitting at idle. The minute I start driving around the temp gauge will slowly drop and eventually drop all the way back to C. It will also climb back up slowly to normal temp if I sit at a light. It has a brand new water pump from napa and a brand new radiator I just put in today since the old radiator started to leak.
This has been an ongoing issue since I put in the new water pump about a month ago and even with the new radiator. Cooling system has been bled each time. Only thing I can think of next is the thermostat. Any suggestions? The oil looks fine just in case people think it's a blown headgasket.
Old Oct 20, 2013 | 10:26 PM
instrument's Avatar
Default Re: 90 Honda Civic Si temp gauge dropping while driving
sounds like thermostat to me.
Old Oct 21, 2013 | 03:01 AM
Freemananana's Avatar
Check that. It's weird your car is getting too cold! The fans may be very effective and just kicking on too soon. That or check your connection for the ECT or whatever controls the dash temp. It could be bad and have something to do with an improper reading.
Old Oct 21, 2013 | 10:09 AM
mouab18c1's Avatar
Yes it is weird. I'm hoping it's just the thermostat. Everything was working fine before replacing the stupid water pump.
Old Oct 21, 2013 | 10:38 AM
Maybe something got knocked loose and clocked the thermostat. It's possible. I'm not sure if the temp sensor for the cluster can get clogged. It's always possible.
Old Oct 21, 2013 | 12:05 PM
mouab18c1's Avatar
The only thing that was near the thermostat that I touched was the lower radiator hose. Besides that nothing was taken off from that side of the car. I'm sure if anything was clogged it would either overheat or just read cold all the time. I'll be getting a new thermostat today "Kicking myself for not buying one yesterday when I bought the radiator" but I should know by tonight.
Old Oct 21, 2013 | 05:40 PM
instrument's Avatar
my car was the same, it got to the point during the winter it would never fully warm up my entire 20mile commute. or go up then slowly go down.
Old Oct 21, 2013 | 06:35 PM
mouab18c1's Avatar
It was the thermostat. Put in a new one and everything is back to normal. Thanks for all the replies and suggestions.
Old Oct 22, 2013 | 03:05 AM
There was probably some material in the water pump that got stuck in the thermostat when you replaced it.
Old Oct 22, 2013 | 09:26 AM
mouab18c1's Avatar
The thermostat looked normal with nothing stuck on it so it might of just been too old. A lot of **** on this car is still from the factory so it wouldn't surprise me
Old Oct 22, 2013 | 10:02 AM
Yup. I run into that a lot on my car too. Vacuum lines that are OEM just fall apart when I go to unplug them. Congrats though. It's always good to see someone solve their problem.
mkentrup3589
Honda Civic (2001 - 2005)
Feb 5, 2016 01:25 AM
miszjackie
12
Mar 25, 2010 05:46 AM
AntMan401
May 25, 2007 08:36 PM
iBrandon
May 20, 2006 03:01 AM
project civic
Mar 16, 2006 09:46 AM
