cams for b18c choice
Hi
Please advise me to make a choice of cams for b18c stock engine
i want to put tham on all stock
What cams are good for that???
I have only plm toda header and tegiwa intake and hondata for mapping
I had very good success with JUN3 Cams, Blox Valvesprings and Retainers. Although looking back I would probably use Supertech instead now. 3 inch intake custom length for optimal performance, ARP studes. Stock JDM ITR block.
JUN 3 cams are proven performers. If the OP is on a budget, the Blox spec Cs are an identical replica of the Jun3. I'm not a big fan of replicas, but if it's all the OP can afford, then so be it.
You can get a Blox head package of cams, springs and retainers for under a grand. That leaves you about $500 for install + tuning which isn't much, but it's doable.
not well on a lower 10.0:1 compression. Those things were made for higher static compression and supplementally parts supplied engines. Those are just too big.
Search user " SOLODC" .. if you want a straight forward, budget bolt on/cammed motor that will make 200+Whp and run 12's in a integra, follow his setup type..
Also using a proven parts help a lot and a good tuner.
littlegreenb18
33
Jan 23, 2006 03:58 PM
Sean Juan
10
Oct 25, 2005 01:47 PM
A2_8U
10
Oct 5, 2005 06:18 PM
