Need help finding the right console & seats for my 90 civic
Hello all,
Just purchased a 1990 civic with a jdm D15b vtec swap. It has crx seats and dash but I want to change a few things. As far as I've seen the 94-01 Integra middle console will fit in this car but I need to make sure. I am looking at buying a middle console from a 98 Integra GSR and need to know if it will fit. Also, I am looking at purchasing the front and rear leather seats from the 1998 Acura Integra GSR, will they fit too?
Any help would be greatly appreciated.
Thanks
Thanks
Hello all,
Thanks
Thanks
Seats. The front seats I believe fit but you need to do a pan swap or change the mounts. Not really positive on that. It will be tight though. And the rear are pretty hard to get to fit right. You have to make your own holes or something like that.
^Do you have pics of the Integra center console with a CRX dash? I'd imagine it wouldn't fit close enough because of the CRX dash's shape (center angled towards driver).
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/installing-new-center-console-3119592/
That's my write up. Should be a sticky! Just kidding. The pictures are mediocre at best.
Do you mean it will not work in general or with the CRX dash?
Pretty sure he's referring to the CRX dash. Normal Civic hatchback dash is simple enough to install the Integra center console into and is universally excepted as a near bolt in with maybe a 98% fit (I'm spitting out random numbers but you understand what I'm getting at). The reason why the CRX dash is being brought up is because the OP stated he has one.
But the integra and civic console is like a 95% fit. The arm rest is tight and the driver side of the console needs a hole drilled.
tfalconier
Nov 23, 2003 12:27 PM
Erik_Pb_Foot
Aug 23, 2002 04:41 PM
