turbo boost question?
Old Oct 20, 2013 | 12:35 PM
farcie123's Avatar
Default turbo boost question?
I have a gsr motor with p73 pistons and rods. im throwing a turbo on it t3/t4. what im really wanting to know is when my boost will begin to build. what rpm maybe? will it be safe to drive it to a tuner?
Thanks!
Old Oct 20, 2013 | 07:53 PM
ricetastic's Avatar
Default Re: turbo boost question?
need more info on turbo size.. just scale your injectors correctly and dont drive (boost) like an idiot and u should be ok
Old Oct 21, 2013 | 05:03 AM
kyden's Avatar
t3/t4 could be one of hundreds of turbos on the market.
Old Oct 21, 2013 | 10:34 AM
Muckman's Avatar
Moderator in Chief
We have a forced induction forum.
Old Oct 21, 2013 | 05:33 PM
$MIKE$'s Avatar
Disconnect your charge pipe and you can drive it anywhere.
I did this on my oem itr motor that I boosted to drive to my tunner 100 miles away it did fine!!
Old Oct 22, 2013 | 06:35 AM
Muckman's Avatar
Moderator in Chief
Its better to pull the wg spring so the maximum amount of exhaust bypasses the turbo so it will not generate boost. If you pull the charge pipe the turbo can overspin trying to generate boost (that is blowing out the disconnected pipe) if you were on the throttle hard.
Unless you have a tiny turbo you can simply stay light on the throttle and no boost will be generated.
Old Oct 22, 2013 | 09:18 AM
farcie123's Avatar
Thanks guys ill probably just baby it there lol. I think it should be fine.
bb_one
Jul 25, 2006 06:52 AM
hotboi850
Aug 30, 2003 08:59 AM
TURBO-JET LUDE
Mar 25, 2003 06:04 AM
vtec.dc2
Nov 7, 2002 10:04 PM
Seraph0
Aug 28, 2001 03:20 PM
