1990 Accord CEL
Hey all,
I replaced the clutch/flywheel assembly and my oil pan gasket yesterday and when I started the car up I now have a CEL.
I have no clue how to read OBD-1 trouble codes and I have gone over every line, connector, bolt, everything to try and find a problem.
Can anyone think of something hidden I may be missing or how to read the trouble code so that I can attempt some form of repair?
Thanks!
Thanks!
should be a diagnostic connector located on or near the passenger side kick panel. mine is blue. then use a jumper wire or pasper clip in the 2 pin connector. turn the key on. The CEL should flash. Long flashes =10,short flashes =1. then do a search on this site for the code. It may be in the FAQ sticky
One Low Accord
May 30, 2008 04:35 PM
silvervtecrx
Oct 10, 2004 07:30 PM
