can low oil cause engine to run warmer
Old Oct 20, 2013 | 07:06 AM
76 camaro car's Avatar
Default can low oil cause engine to run warmer
My 94 accord yesterday afternoon the temp gauge went up to half way. Its normal running temp is about 5/16" below half way. The engine cooling fan seems to be working properly and there are no visible leaks anywhere. I checked the water in the radiator this morning and added maybe a pint to top it off. I checked the oil and it is just on the tip of the dipstick. I immediatley filled the oil to the correct level. Can the engine being low on oil make the temp gauge to read high? I replaced the thermostat several years ago and although most people say first thing is its the thermostat, really how often does a thermostat go bad. To be honest Ive never seen one go bad.
Old Oct 20, 2013 | 07:54 AM
Fitz Williams's Avatar
10 Year Member
Default Re: can low oil cause engine to run warmer
As long as you are getting oil to the bearings the temp should not go up. And I am guessing that no oil warning light came on. If you had to add a pint to the radiator (and not the overflow bottle) then that is the place to look. Somewhere water is leaking out of he cooling system.
Old Oct 20, 2013 | 08:00 AM
I did a pressure test on it. Pumped it up to 16psi. The pressure bleeds off pretty quick but I don't see any leaks. I'm not sure if the adapter I was using is leaking or what. With as fast as it bleeds off I should see a leak somewhere. I don't think its a head gasket because the car runs great. Has me baffled.
Old Oct 20, 2013 | 09:08 AM
Just took the car on a 15 mile ride and when I came back let it idle in the driveway in gear for 5 minutes. It ran normal temp the whole time. I think the adapter on the pressure tester I was using leaked. I could hear what sounded like bacon frying where the adapter was connected at. I think that is why it leaked down. Still don't know why it ran warmer than usual yesterday though. There has to be a reason.
Old Oct 20, 2013 | 03:49 PM
djkurious's Avatar
Maybe you were heavy footed that day...
Old Oct 21, 2013 | 01:26 PM
I found a tiny trickle leak where the upper radiator hose connects to the engine (between the aluminum piece the hose goes to and the engine). Is there a gasket that goes between the 2 pieces? It only trickles a little bit when first started and goes away as the engine warms up. Tried to tighten the 2 bolts that hold it on but they are already very tight. Also is a pint low on water in the radiator enough to make the gauge read a little higher than normal?
darkstormcr
12
Aug 11, 2012 07:45 AM
cagedteg
May 10, 2009 06:47 AM
sorullo
Jun 18, 2008 06:38 PM
mr tl
Mar 14, 2002 11:34 AM
