Type-r tran with quaife lsd help!
Im hearing and seeing online reviews, ATF is the new MTF? Well with quaife lsd that is...
TRUE? FALSE? and what brand ATF? honda? does brand matters? or is it in the weight?
thanks thanks thanks ahead!
This ive never heard of! Ive always ALWAYS ran either gm or pennzoil sychromesh! Amsoils pretty good as well but its expensive! Ill never ever use nething other than those! Idk y ppl would use atf in a manual trans...dnt think thatd have a happy ending
so i have done alot of researches. most of them only uses GM fluid because of grinds or do to being old. What if my trans is running and shifting smooth. im doing my clutch, so i figure i change everything...
Doubt you can get it at a normal parts store. They're headquartered not far away from you in Rancho Cucamonga so it shouldn't take much effort to find some locally.
B18C5-EH2
Dec 14, 2001 12:04 PM
