Del Sol Tach,Speedo,Temp and Fuel Gauges not working
Old Oct 19, 2013 | 11:16 AM
DSolBuccFann's Avatar
Default Del Sol Tach,Speedo,Temp and Fuel Gauges not working
Quick story, I blew some fuses trying to jump my car. I am able to start the car now and everything works fine, but the speedo, tach, temp gauge and fuel gauge are now not working. Is there a fuse for all of these in one or am I missing something that may have blown from the bad jump? Everything worked fine before the jump issue. I just drove the car down the street and everything is fine except for the cluster. Any ideas?
Old Oct 19, 2013 | 04:17 PM
Lizardslap's Avatar
Default Re: Del Sol Tach,Speedo,Temp and Fuel Gauges not working
you blew some fuses keep looking under hood an under dash fuse boxes something is blown
use a volt meter on them they can look fine and not be somtimes
Old Oct 21, 2013 | 08:30 PM
Thanks...I did pull all of the fuses out and looked at them, but you might be right on them looking fine and not working right. Just wasn't sure if someone knew the exact one it was. Thanks though!
xChrizcrozzx
Mar 18, 2015 12:11 PM
sto4gcivic
Aug 28, 2008 03:58 PM
ahloung
Mar 9, 2006 08:12 PM
AzntaggeR
Apr 14, 2003 12:01 AM
pdiddyparsons
Apr 8, 2003 08:52 AM
