95 honda civic temperature sending unit
Old Oct 19, 2013 | 11:09 AM
molukuanghuan's Avatar
Default 95 honda civic temperature sending unit
Hello guys, i have a 95 civic, the temperature gauge doesn't work, i want to test the temperature sending unit, but i can not unplug it and i saw the sensor is inside the engine, anyone knows how to replace the sensor? Do i need to open the engine to replace it? thanks
Old Oct 19, 2013 | 12:52 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: 95 honda civic temperature sending unit
Old Oct 19, 2013 | 01:09 PM
Meoshe's Avatar
You should be able to just unscrew it, it should be 12mm. Coolant will leak out so be ready for that, its not a lot but if enough leaks out you will probably have to bleed the system.
Old Oct 20, 2013 | 06:59 AM
Thanks, but the screw is not 12mm, it's very tiny and it seems like coming out from inside engine.
Old Oct 20, 2013 | 02:10 PM
Thanks, already replaced it, it works fine now,thank you!
glasscat
Dec 13, 2018 02:48 AM
Beto760
Engine Management and Tuning
Jun 2, 2010 06:40 PM
slip91
Feb 23, 2008 10:55 AM
