92 civic dies at idle wont start
Old Oct 19, 2013 | 10:50 AM
bmxerforlife58's Avatar
Default 92 civic dies at idle wont start
I have a 92 civic with a gsr on boost. Last night i was sitting in a parking lot and my car dies out of no where. I go to crank it back up i get nothing..The check engine light is staying on. It doesnt cut off after 2 seconds like normal nor will it flash any codes when i jump the jumper. Ive checked every ground, replaced main relay, checked all the wires with voltmeter on harness side of volt meter, tried 4 different ecus, checked every fuse 2 times with test light, tested ignition coil, tried reseting ecu, checked all harness connections for lose wires or bad connections, took off the resitor box and connected all wires back to normal to eliminate that from being bad. no matter what i do the check engine light is 100 percent solid i have no spark and my car wont start. Additional information is the fuel pump is on its own relay and it is working fine. ive never came across the check engine light problem im confident if i figure that out my car will run. thanks in advance for help
Old Oct 19, 2013 | 08:49 PM
that_boy_sammy's Avatar
Default Re: 92 civic dies at idle wont start
You kinda solved your own problem there buddy. You said you have no spark. Get a new dizzy or replace all the parts inside of it like the cap,rotor,icm, and ignition coil. I'm 99.99% sure its the ICM or Coil.
Old Oct 20, 2013 | 11:09 AM
Actually figured it out the map sensor fried. Replaced it check engine light went away and everything primed like it was suposed to.
mkhalid8
Jan 31, 2015 01:11 PM
Forgotten_0182
Jan 23, 2008 01:09 PM
PACT man
Jan 10, 2007 06:47 PM
redlines4us
Nov 18, 2005 07:37 PM
No More Civic
10
Aug 27, 2002 09:35 AM
