Axle Problem!!
Old Oct 18, 2013 | 04:13 PM
nizle144's Avatar
Default Axle Problem!!
I have a 91 DX with a B18A1 Block, B18C Head, and a B16 tranny. When driving, the driver side starts to pop and shake bad. But it doesnt do it all the time and usually when you speed up to 55 it goes away. I went to replace the axle last weekend and got the axle nut off, got the ball joint apart, and once i got the axle loose in the hub and started to pull it out, it kept getting hung up right at the end. Almost like it was getting hung on the bearing but im not sure. Any input would be greatly appreciated.
Old Oct 18, 2013 | 04:47 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Axle Problem!!
Can you bump it out with a large socket and a hammer?
Old Oct 18, 2013 | 04:52 PM
nizle144's Avatar
Im not sure i didnt try. I didnt want to force it out and screw something else up
Old Oct 18, 2013 | 05:23 PM
Freemananana's Avatar
You usually gotta force those things out. They are meant to be tight. And if you are going to replace it, beating it won't hurt too much.
Old Oct 18, 2013 | 05:29 PM
nizle144's Avatar
My next question is which axle should i be buying to replace? 90 Integra or one for the b16 trans? I havent seperated it from the intermediate yet but the way it looks, that end of the axle is a female end and the one for a 90 Integra is a male.
Old Oct 18, 2013 | 06:04 PM
4drEF's Avatar
Keyboard Humorist
The axle you buy depends on what intermediate shaft you have in there.
For more info, click --> Read this!
Old Oct 18, 2013 | 06:16 PM
nizle144's Avatar
Is there a way to tell the difference between the two without taking axle out? So I could buy proper axle before I start?
Old Oct 18, 2013 | 06:41 PM
Crawl under the car and try and get a look at the serial or part number portion stamped on the side of the shaft.
Old Oct 18, 2013 | 06:46 PM
nizle144's Avatar
Side of axle shaft or intermediate?
Old Oct 19, 2013 | 06:20 AM
Intermediate shaft. The previous link shows you.
Old Oct 19, 2013 | 06:45 AM
nizle144's Avatar
Thanks man!
BoSox46GSr
Mar 9, 2008 10:16 AM
GarageAlchemist
Jul 27, 2006 03:04 PM
BLK99VTECR
Oct 3, 2005 09:59 PM
The Phil
Aug 26, 2005 10:33 PM
JDM96SpecCTR
13
Dec 6, 2004 01:34 PM
