5lug conversion ?
Old Oct 18, 2013 | 10:40 AM
amoras10's Avatar
Default 5lug conversion ?
Hello,
I know that i can convert from 4x100 to 5x100 from integera etc.,
but in europe, my city its not common car,
can i make front and rear disk swap to 5x100? from accord? or other cars?
Old Oct 18, 2013 | 12:04 PM
GSR CRX's Avatar
Default Re: 5lug conversion ?
if you are using eg/ek/dc knuckles then you can find a set of USDM 32mm integra type r hubs for the front. for the rear you will obviously need to convert to disc first. if you are fortunate enough to locate the integra type r rear trailing arm then use those. if not, use the 4x100 rear disc trailing arm with a set of bb6 prelude rear hubs with a mazda 626 axle nut.
front hub: 44600-ST7-R00
rear hub: 42200-S30-C51
here is the link that i have used when i did mine. i have not had any issues with this setup.
https://honda-tech.com/forums/suspension-brakes-54/5-lug-conversion-using-4-lug-spindles-front-rear-1978033/
delsolo95
May 19, 2012 11:12 AM
quiocho8o8
Suspension & Brakes
Apr 5, 2010 07:28 PM
88 EF Hatch
Mar 3, 2009 10:12 AM
88 EF Hatch
Mar 3, 2009 08:47 AM
acurateggy93
Apr 12, 2005 10:12 AM
