Misc. b & d series, eg, ek and ef parts
Cleaning out my garage and parts sheds, will have more listed soon.
Payment : Cash or paypal. I am paypal verified.
Shipping: I will ONLY ship UPS, you will have a tracking number within 24hrs of payment clearing.
Contact: Best way to contact me is through private msg.
Prices ARE negotiable. I will be updating with new parts over the next few weeks. Thanks.
New ARP pro series headstud kit for b16a2 - Sold thank you hondatwincam
New oem honda bolts/seals all were purchased for b16a2.
Pn: 95701-0601808 bolt 8x28 (.78 new) (qty. 10) .50ea
Pn: 94050-06080 nut 6mm (.16new) (qty. 11) .10ea
Pn: 94050-08080 nut 8mm (.18new) (qyt. 4) .12ea
Pn: 95701-0601408 bolt 6x14 (.60new) (qyt. 2) .40ea
Pn: 92900-060280B stud 6x28 (.63new) (qyt. 3) .40ea
Pn: 9200-080351B stud 8x35 (.86new) (qyt. 4) .60ea
Pn: 16638-PH3-S00 fuel rail gromet (.96new) (qyt. 3) .70ea
Pn: 91213-PR3-004 oil seal (5.48new) (qyt. 2) 4.50ea
Pn: 90026-PR3-003 tensioner bolt 4.99new) (qyt. 1) 4.00
Pn: 13622-PR3-000 belt guide (3.36new) (qyt. 2) 2.75ea
Pn: 91214-PLE-003 front oil seal (12.95new) (qyt. 1) 10.00
Pn: 95701-0804508 bolt 8x45 .83new (qyt. 1) .60
Pn: 90011-PH3-000 flywheel bolt 12mm 3.71new (qyt. 4) 2.70ea
Pn: 90034-689-000 clutch bolt 4.22new (qyt. 4) 3.20ea
Pn: 36172-P08-015 vtec gasket (5.71new) (qyt. 1) 4.60
Pn: 16741-PG7-005 fpr o ring (1.72new) (qyt. 1) .80
Pn: 95701-0602508 bolt 6x25 (.63new) (qyt. 3) .40ea
Pn: 91212-PR3-003 oil pump seal 6.81new) (qyt. 1) 5.75
Pn: 95701-0807008 bolt 8x70 .41new (qyt. 2) .20ea
Pn: 95701-0602008 bolt 4.20 .16new) (qyt. 5) .10ea
Pn: 95701-0608008 bolt 6x80 (.37new) (qyt. 1) .25
Pn: 90026-PT0-000 stud 8x37 (1.94new) (qyt. 2) 1.00ea
Pn: 95701-0803508 bolt 8x35 .26new) (qyt. 1) .10
Pn: 30110-PA1-732 dizzy o ring (1.45new) (qyt. 1) .80
Pn: 91324-PR3-003 breather o ring 1.45new) (qyt. 1) .80
Pn: 95701-0804008 bolt 4x80 (.36new) (qyt. 4) .25ea
pn: 15650-P30-000 dipstick (12.17new) (qyt. 1) 10.00
Carbon invader style hood, carbon creations brand ( has some spiderweb cracks, hood pins locking style, and a couple spots on the bottom side where it rubbed) - $125 pickup only
New drivers engine mount for 96-00 civic $40, new aem bypass valve $25, 96 dx 5spd ecu P2E $30
99-00 Oem Silver Drivers fender - $50 Pick up only.
92-95 auto to manual trans mount /w urethane bushing (new never installed) - $60
B16a2 head, was taken to machine shop to to have it checked for warping(have a receipt), its been sitting for awhile will need the valve seats cleaned up. Comes with all drivetrain, valves, cams and gears. Almost all the bolts are still in the oem honda bag. Does not have a vc, im, or distributor. $300
Obd0 ls head, 147K was removed for a vtec head, Comes with that you see in the pics, and im, no cams or vc. - $40
obd1 ls head, no valvetrain, cams, or vc. I have no info on this head it was thrown in with a trade - $60
92-95 power steering rack, drivers side has newer innter/outer rods, removed for a manual rack - $25
96-98 civic black housing headlight, no problems - $25
Two mufflers, top one is a ractive, bottom one no name /w silencer - $20ea
b16a2 bare block, has arp mainstuds, block was shaved for a turbo, will need a hone, no crank. - $60
Oem Doors - $60 ea $100both
Green passenger fender cut for side marker - $30
Headliner - $40
Sun visors - Sold
Steering wheel - $5 /w airbag $30
Trunk - $40
Sideskirts (selling as pair only) - $50
Side molding - $15ea or $30 ea side, $50 for all
Rear seat - $20
Carpet - $40
Door handles - $15ea or $25 for both
Front door glass - $40ea or $60both
Hood - $75
Engine/trans - sold
da integra mounts (filled) - $25all Prelude passenger mirrior - $5
da integra console /w nice red stich boot - $30
92-95 oem wing (broken tip) - gone 92-95 dash trim - $20
99-00 si rear sway bar (endlinks have been cut) - $50 99 ex brake master cylinder /w booster (worked fine last week no leaks) - $50
driver side 99-00 si mount braket (missing one stud) - $45 99-00 civic rear mount - $ PPU 97 integra ls power steering brackets - $100
P72 engine bracket drivers side /w bolt - $100 99-00 civic rear engine mount - $25 96 integra intake manifold brace - $10
Pod came out of a eg - $20 obd2 p72 ecu (worked with no problems a month ago) - $100
obd2a-obd2b (has tape on a couple wires and a jumper on another, worked fine when removed)- $90 obd2b-obd1(has tape on a couple wires, worked when removed)- $30 obd2a-obd1(rywire brand,worked fine, has a small spot where the shielding has a split) - $50
Headliner - $40
Sun visors - Sold
Trunk - $40
Rear seat - $20
Carpet - $40
Hood - $75
Engine/trans - sold
do you have front end wire harnesses? (headlight/turn signal/fan/horn)
and also do you have cabin harness?
clutch/brake harness
must be uncut and in good working condition. shipped to 34479
thank you
thank you
Sorry ended up getting a buyer on the whole package, Thank you though
If you are referring to an ek yes i do cabin is uncut except for the 4 or 5 wires that go to the wipers.
It do but was cut in the front before i got the car.
Needforspeed502
Texas -OK -LA (Sales)
66
Nov 30, 2015 07:34 PM
hybrid89
Dec 30, 2014 07:25 PM
