Constant air in coolant...
I have a 93 Civic with a stock d15b7. I had oil leaking into my coolant, and a endless stream of air coming up through my radiator. So much so, it blew my overflow cap off... So, I replaced my head gasket. I STILL have a steady stream of air, but no more oil in my coolant... I know I should have checked the head for warping, but it's never overheated and I thought it would be good.
Is there any other possible way air can get into the cooling system? I'm not loosing any coolant, no visible leeks or smells, nor am I burning it. It causes my idle to surge a bit, which should be because of air reaching the IACV. Could there be a small leak by a clamp sucking in air? I know it's pressurized, and it should leak out, but I have read the bleeder valve can draw air into the system if it's not bled correctly.
I know some Chevy and GM's the intake manifold gasket can leak air into the cooling system (or coolant out), but I don't think that's the case with Honda.
Any suggestions would be appreciated. Other than the idle surging and air in coolant she runs great, so I'm confident I replaced the gasket correctly.
sounds like the HG is still leaking. best way to tell is to do a leakdown test on all 4 cylinders, and do it with the radiator cap off and the coolant topped off. if the coolant rises at all when you pressurize a cylinder, then the HG is definitely still leaking.
JaguarS4R
Honda Civic (2001 - 2005)
12
Feb 28, 2010 04:12 PM
return_2020
12
Feb 12, 2005 05:51 AM
ZC88CRX
Jan 2, 2004 05:12 PM
