Motor oil change being weird help please !
Old Oct 15, 2013 | 12:36 PM
ODbuilt's Avatar
Default Motor oil change being weird help please !
So I changed my motor oil myself & the oil filter . I used one small bottle of Castrol GTX 10w-30 oil . 5 mins after the change I checked the dipstick and there was no oil on it . So I turned the car on and let it idle for a little . I checked the dipstick again and the oil was half way up the stick , what could be wrong ? Also I put antifreeze in and then drove around the block for a little , came back home and checked it and it had like nothing in the radiatior , the overflow was bubbling too .
Old Oct 15, 2013 | 12:49 PM
Freemananana's Avatar
Default Re: Motor oil change being weird help please !
I think you are doing this wrong. You car needs almost 4 quarts (small bottles) of oil. Not 1. When the car is running, oil moves. The dipstick gets oil on it. You wipe off the oil and then put it back in and check it. As for antifreeze, did you bleed the system of air? You have to fill it, bleed it, fill it, bleed it, ect until there is no air. Then I usually put some in the overflow tank. There is a min and a max marked on it.
Old Oct 15, 2013 | 01:18 PM
ODbuilt's Avatar
My friend said I needed around 4 bottles but I didn't wanna mess anything up in the long run . But how would I bleed the system of air ?
Old Oct 15, 2013 | 01:22 PM
F22Master's Avatar
How much oil did you put in, in total?
Old Oct 15, 2013 | 02:05 PM
ODbuilt's Avatar
One of the small bottles
Old Oct 15, 2013 | 02:12 PM
jlicrx's Avatar
Old Oct 15, 2013 | 02:29 PM
949's Avatar
949
are you being serious?
did you drive it with only 1 quart bottle of oil in the engine?
Old Oct 15, 2013 | 02:32 PM
ODbuilt's Avatar
Yeah because I wasnt sure how much to put in . But I was driving around the block a few times
Old Oct 15, 2013 | 02:35 PM
ODbuilt's Avatar
Originally Posted by jlicrx
Thank you !
Old Oct 15, 2013 | 03:48 PM
Google it next time! Please One is not enough. Hopefully nothing happened to the motor.
Old Oct 15, 2013 | 04:08 PM
90_EX_Civic's Avatar
how much torque did you put on the drain plug, and how much torque did you put on the filter?
tell me you didn't over torque them?
Old Oct 15, 2013 | 06:26 PM
ODbuilt's Avatar
I couldn't find the drain plug for the coolant so I did the hose way & I didn't over torque the filter
Old Oct 15, 2013 | 06:27 PM
ODbuilt's Avatar
I know I just wasnt thinking about googling everything but I will if I'm iffy about anything else !
Old Oct 15, 2013 | 06:33 PM
Riceburner247's Avatar
I refuse to believe that the OP is serious.
If you don't know how to work on an engine, DON'T. Especially if you can't take 2 minutes to research a simple question.
ramboPandA
Oct 4, 2013 10:20 PM
ceyazzie
Dec 20, 2008 07:52 AM
AMG
44
Aug 17, 2004 08:11 AM
integragsr6
Honda Motorcycles
Mar 31, 2004 07:09 AM
94GsRacer
Sep 19, 2002 02:43 PM
