Strut bars - upper/lower? Which one to get?
Old Oct 26, 2002 | 09:01 PM
SoCalifTypeR's Avatar
Default Strut bars - upper/lower? Which one to get?
I did a search, and I am a newbie....
sorry, have no idea what the difference between upper and lower Strut bar is.
I have a '92 civic 4 door. was looking at a mugen strut bar, $48. good deal?
Old Oct 26, 2002 | 09:24 PM
SpoonFedHatch's Avatar
Default Re: Strut bars - upper/lower? Which one to get? (SoCalifTypeR)
upper is called a strut bar (for strut mounts) and lower is anti-roll bar or sway bar...the horizontal tension can be adjusted
Old Oct 26, 2002 | 10:03 PM
get both....strut bar, sway bar, strut bar, tie bar, candy bar...etc
Old Oct 26, 2002 | 10:14 PM
Anderson's Avatar
wow $48 for a mugen????
most likey its not real
Old Oct 26, 2002 | 10:18 PM
IS3Fifty's Avatar
Default Re: Strut bars - upper/lower? Which one to get? (Anderson)
yeah he definately saw that on Ebay. its a Mugen "style" as the rip offs try to refer to it as "cheap ****", but since your new its all right man. be sure to buy both the upper and lower for better suspension stabilization. if you have to get only 1 get the upper first.
Old Oct 26, 2002 | 10:41 PM
madwilliam's Avatar
Default Re: Strut bars - upper/lower? Which one to get? (SpoonFedHatch)
there are strut tower bars for front and rear, mounted on top of the strut pillars. the lower bar in the rear is a tie bar.
Old Oct 26, 2002 | 11:09 PM
eg6sir-s's Avatar
first off, don't buy something because it's mugen(or any so called jdm brand) style anything...save yourself the time and money...and get something that will work for your car...and not because its a 'style' of another.
since you'ved got a sedan(4door) best suspension setup to get are:
front upper strut bar(neuspeed, sprint, cusco, jic, mugen)choose one
front lower tie bar(cusco, jic, neuspeed)choose one
if your sedan is not an ex model get a front sway bar off a gsr or ex/si civic
if your sedan is an ex model you dont have to worry you already have a front sway bar
rear upper strut bar(neuspeed, cusco, jic, mugen)choose one
as for the lower you dont have to get a rear sway bar and lower tie bar...just get one or the other
if your 4door is an ex model you already have a rear sway bar...which means you dont need anything else...
rear sway bar(stock gsr or suspension techniques)
rear lower tie bar(jic)
this is just my opinion on things...feel free to use this as a guide...good luck
[Modified by eg6si, 12:12 AM 10/27/2002]
Old Oct 26, 2002 | 11:19 PM
Amuse9's Avatar
Default Re: Strut bars - upper/lower? Which one to get? (eg6si)
I want to either get the EK front strut bar by SPOON or SKUNK 2
But both are pretty darn PRICEY!!
[Modified by CivicSedan, 12:20 AM 10/27/2002]
JoeBull
Sep 1, 2010 07:47 PM
boxeocampeon
Suspension & Brakes
Sep 16, 2009 08:38 PM
kos99ngel
Oct 14, 2005 01:03 AM
gofastgsr
Aug 20, 2003 12:56 PM
sloaccord96
May 15, 2002 09:18 PM
