1998 Civic over heating?
Old Oct 14, 2013 | 07:00 PM
JohnRosalez's Avatar
Default 1998 Civic over heating?
Ok so..
I was sitting in my car waiting for a friend when i noticed my temp gauge was very high.. I turned it off as soon as i noticed it, parked it..
I noticed the radiator reservoir was almost empty..
I filled it back up...
I let it sit and it for a while then I drove it about an hour later..
Everything seemed fine, until i noticed the temperature gauge started to move high when i was at a red light...
I pulled over for 15 minutes, checked the coolant-- the tank was still full...
I decided to drive the same way back home, but the temperature gauge did not rise on the way back home..
I have work tommorow morning..
Does anybody have any ideas as to whats going on now all of a sudden??
Please
Old Oct 16, 2013 | 05:14 AM
Grape Ape Guy's Avatar
Default Re: 1998 Civic over heating?
System might have air in it
Old Oct 16, 2013 | 02:29 PM
Johnne625's Avatar
Has this issue been resolved yet? If not you may want to do a flush of your cooling system, use fresh coolant when refilling, and check everything in the cooling system. Making sure your radiator cap isn't bad, t-stat still opens properly, all hoses aren't cracked or degrading, make sure there aren't any coolant leaks coming from anywhere, etc. Had to flush my cooling system a few times before i realized my t-stat was stuck shut and wasn't opening. IN the end all i needed was a new t-stat and ta-da problem solved. Oh and also make sure to bleed all your air out once you refill it with coolant, you'd be surprised what a tiny air buble can do
Tmich91
Dec 13, 2018 03:27 PM
Dm914
Jul 21, 2017 07:40 AM
TOO MUCH TORQUE
Jul 28, 2010 09:21 PM
RG400SmartTowel
Aug 11, 2009 12:34 AM
Mario.
Mar 5, 2005 06:30 PM
