VSS metal housing broken - part number?
Old Oct 14, 2013 | 05:41 PM
JWFokker's Avatar
Default VSS metal housing broken - part number?
Recently purchased a 95 Civic EX (EJ1 coupe) from a friend knowing that it needed a lot of small repairs. The speedometer worked intermittently and today while I was changing the engine oil and MTF I went to remove the VSS and found out why it isn't working reliably. The metal housing that holds the VSS onto the transmission is broken. Literally snapped off. My issue now is that while I can find the sensor itself online, I can only find the whole assembly (used) on ebay. Anyone know where you can get the whole thing? I couldn't pull anything up on Majestic Honda parts search.
Old Oct 15, 2013 | 07:17 AM
angrysmileyface's Avatar
Default Re: VSS metal housing broken - part number?
Recycling yard. I snapped mine (Apparently Im stronger than the metal is when torquing down). Its a snug fit so it doesnt slide out so I had to goto a parts yard and get the whole assembly. Gotta love pull apart.
Yuta
Sep 1, 2020 12:33 PM
gd1107
Honda Civic (2001 - 2005)
Sep 28, 2017 08:03 AM
b20vtecturbe
Jan 22, 2017 01:39 AM
loeb
Honda CR-V & Element
Feb 7, 2012 11:04 AM
velisma
Transmission & Drivetrain
18
Jul 24, 2009 06:15 AM
