oil loss from headgasket?
Old Oct 26, 2002 | 08:49 PM
redteg1's Avatar
Default oil loss from headgasket?
well i have this problem with burning up oil. my friend told me he saw it blue coming out of my exhaust. i also did a compression test and some white smoke came out of the area. does this mean the headgasket is no good. and is that why i could be burning up oil?
Old Oct 27, 2002 | 06:58 AM
redteg1's Avatar
Default Re: oil loss from headgasket? (redteg1)
ttt
Old Oct 27, 2002 | 09:59 AM
non-VTEC's Avatar
maybe your rings are worn.
what colour are the tips of your spark plugs?
if you headgasket was leaking or went bad you will most likley burn engine coolant before you burn engine oil.....
Old Oct 27, 2002 | 10:02 AM
Full Race EG's Avatar
Default Re: oil loss from headgasket? (non-VTEC)
Old Oct 27, 2002 | 08:15 PM
redteg1's Avatar
tips are fine. wat rings are u talking about?
Old Oct 27, 2002 | 08:16 PM
redteg1's Avatar
tips are fine. wat rings are u talking about? the vavle cover gasket rings??
Old Oct 27, 2002 | 08:18 PM
piatl7il77's Avatar
what where the #s that you got from the compresion test? He is talking about your piston rings. it may also be you valve stem seels.
Old Oct 27, 2002 | 09:36 PM
redteg1's Avatar
Default Re: oil loss from headgasket? (piatl7il77)
ok i know this sounds ridiculous...but i retested like 4 times and got the same results...but here they are. 190, 210, 200, and 10...not in that particular order tho...but u get the idea. i don't understand tho..the car runs fine...strong as hell for only a i/e gsr 14.9@93mph.
Powelly
12
Sep 5, 2008 09:54 AM
blackmfoggie
Sep 7, 2007 07:34 PM
so-cal-em1
May 9, 2007 11:38 AM
vxnine
18
Oct 11, 2003 07:24 PM
