Weird Sound coming from turbo! Video inside!
Old Oct 14, 2013 | 10:12 AM
JHipps's Avatar
Default Weird Sound coming from turbo! Video inside!
Ok, So my car has been in the garage for about a week and a half now. I just upgraded my intercooler, exhaust manifold, cams and went to a 3" open downpipe. I went from b16 to Type R cams. Before i did all this my turbo spooled fine and did not sound like the video. Any ideas why it sounds like that?
http://s453.photobucket.com/user/WtF...7032d.mp4.html
Specs on car:
B16 Head
-Supertech Springs and Retainers
-97 Spec ITR Cams/ SKunk 2 Adj. Gears
-R/C 750cc injectors
B18A1 Block
-Completely stock
Edelbrock Performer X Intake Manifold
65MM Pro. Products TB (TB and IM are port matched)
Stock Map Sensor
2.5" Piping
Garrett gt28r .60 a/r turbo on 7psi
3 inch open downpipe
CUstom Mini Ram turbo manifold
p28 Ecu
Redline= 7200
Old Oct 14, 2013 | 10:49 AM
MantisX's Avatar
Default Re: Weird Sound coming from turbo! Video inside!
Sounds normal to me?
Old Oct 14, 2013 | 11:17 AM
JHipps's Avatar
I'm not sure. That sounds different than before I changed everything out
Old Oct 14, 2013 | 11:26 AM
Dark_Teg's Avatar
Sounds normal.
Old Oct 14, 2013 | 12:23 PM
TheShodan's Avatar
Moderator
sounds normal with a car with only a downpipe on it.. what were you thinking you heard?
Old Oct 14, 2013 | 12:28 PM
JHipps's Avatar
I just wanted to make sure it wasn't something. Else or the turbo wasn't going bad. I guess the sow pipe really changed it that much
Old Oct 14, 2013 | 12:31 PM
TheShodan's Avatar
Moderator
There's not baffling, no backpressure, no muffler, nothing..... It changes behaviour a little, and its annoyingly loud, but otherwise,no... sounds fine.
Old Oct 14, 2013 | 12:32 PM
JHipps's Avatar
Down*
Old Oct 14, 2013 | 09:49 PM
JHipps's Avatar
Turbo doesn't seem like its holding any boost...and the vacuum gauge went down from what it used to be at
Old Oct 14, 2013 | 10:09 PM
TheShodan's Avatar
Moderator
you've barely moved that turbocharger from the video. vacuum gauge is going to go down because you have no exhaust system. its going to be a bit lower.
How do you mean "hold boost?" spikes? creeps? leaks? be more clear. it sounds normal ..
Old Oct 15, 2013 | 04:45 AM
motoxxxman's Avatar
totally normal for an open exhaust. listen to my car in these vids...
I'm running a 2.5" downpipe and flexpipe to a 2foot long section of 3" pipe.
first vid you can hear it at the 0:16-0:19 mark, and a little right in the beginning.
second vid about the same, 0:16-0:19.
third vid at 0:02-0:05 and 0:14-0:17
(my setup from these vids is b21a1 all stock internals besides supertech inner valve springs and oem h23 rods, running 8psi from a super60 t3)
Old Oct 15, 2013 | 04:27 PM
Tippyman's Avatar
sounds like a turbo'd car to me.
Old Oct 16, 2013 | 07:48 AM
JHipps's Avatar
Feels like there is a leak somewhere and feels like it just isn't building at all
Old Oct 16, 2013 | 08:22 AM
Tippyman's Avatar
Possible, but from the video you posted, it sounds normal. We cant hear a leak.
Old Oct 16, 2013 | 08:58 AM
TheShodan's Avatar
Moderator
Again, its going to sound like that because of what you did. Check for boost leaks, missing wastegate fire rings, cracked couplers, missing manifold/turbine bolts, etc.. Look at your boost gauge and see how its building boost.
If none are found, Keep driving.
Old Oct 16, 2013 | 04:29 PM
wantboost's Avatar
Who is Mr Robot?
lol turbos whistle, just what they do... ever been next to a semi on the highway?
You'll hear it more with an open downpipe/straight exhaust because a typical exhaust tunes it out unless you're running high boost pressures
JHipps
Oct 8, 2013 10:17 PM
JHipps
Oct 8, 2013 09:23 AM
JHipps
Oct 6, 2013 10:05 AM
aleEvo
Apr 26, 2012 01:56 PM
neoc03
Nov 23, 2011 08:36 AM
