B18c1 swap in 97 rs idles at 5k
Ok so I put my b18c1 into my integra the other day and it starts right up but shoots straight to 5-5.5k rpm. I used brake cleaner around the intake manifold where it meets the head to see if air was escaping but nothing.
Here's some problems with the motor:
-Broken tps but I replaced it, just haven't calibrated it
-evap sensor isn't plugged because there is nowhere to plug it on the gsr
-need to wire vtec/knock sensor
Also, I already adjusted my tb cable so it can't be that. I just never had this issue before.
