Swap Troubles
Swap Troubles
Well I just swapped my B18C1 into my 97 Coupe and when the car starts it starts revving like crazy at a high high high idle. Not sure what to check....Im having trouble figuiring out all the vaccum hoses near the intake manifold which ibelieve are many return lines for the coolant of the radiator or something of the sort...need help and also im havbin trouble wiwring my stock 97 throttle cable to the GSR TB...any help would be good o and 00 P2T ECU(Si)
The TPS sensor was replaced from my 97 civic onto the GSR because the old one wasnt there....not sure if this could affect the high revving.
Re: (StreetRacinThug)
ok, ill try and help you out here i had this trouble in my 96 about a year ago or so...my issue was a bad fitv, i just made a block off plate been good ever since...an erractic idle can be caused by ALOT of different things...check these pages out
http://www.knology.net/~jediklc/
(under quick links..you want to read about proper TPS replacement...it needs to be calibrated, probably your issue
https://honda-tech.com/zerothread?id=1003988
Modified by frankgrimes at 5:48 PM 3/10/2006
footwork mastery
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetRacinThug »</TD></TR><TR><TD CLASS="quote"> Also how do I get my tachs to work....they are not working...anyone know?</TD></TR></TABLE>
do you mean tachometer? if so you only have one...
Re: (PurpleEKHatch)
sorrry let me be specific my Tachometer and Speedometer dont work anyone with any insight...my TB is also needed to be hooked up
check the connection on you vss (vehicle speed sensor)...it plugs onto the top of your transmission case...contacts might be dirty/plug might not be connected
this link has a picture of what iam talking about
https://honda-tech.com/zerothread?id=1364578
Ekid97
08-15-2017 05:04 AM
89efDUSTY
11
05-26-2011 05:14 AM
97ex082391
04-21-2011 07:10 PM
