cusco suspension info?
Old Oct 12, 2013 | 08:51 PM
jdmsleeper12's Avatar
Default cusco suspension info?
I just bought an Acura integra, and just found out it has Cusco full adj coil overs damper.
I cant find any information on it. i try google, but it keeps popping up the ones for RSX or a different version of cusco suspension. The one thats on my DC is for an ITR, because of the rear LCA...
any info will help. More pics later, once i get em clean up and off.
Retail...
facts...
Thanks!
Old Oct 12, 2013 | 08:54 PM
Default Re: cusco suspension info?
Bottom is blue
Top hat is blue with Adj damper
Coil over is silver
springs are black
Old Oct 13, 2013 | 04:31 AM
kaycee_00's Avatar
Those are cusco zero-2 coilovers.
https://honda-tech.com/forums/acura-integra-type-r-8/cusco-coilovers-198081/
Old Oct 14, 2013 | 06:25 AM
94rs-turbo's Avatar
good setup
Old Oct 14, 2013 | 07:57 PM
thank you thank you!!!
Old Oct 15, 2013 | 07:00 AM
Todd00's Avatar
I said I don't want a title!
How many miles on them? If a lot, there is a pretty good change they are going to need to be rebuilt. I would start checking for who could do that if you intend to keep them.
That's the problem with some of the JDM coilovers...it's a pain getting them serviced.
Old Oct 15, 2013 | 09:37 PM
well by the looks of it, LOL! its dirty but not rusty, umm i acutally rebuilding the engine rite now. The previous owner lost the lug nut key. -_-, i had to weld the lug nuts to unbolt the wheels. Haven't yet got to test out the suspension to see if its blown/dead recently purchased. 2 days later spun bearing, with oil pass the 2nd dot on the dip stick... turn into rod knock, then bang seized, LOCKED! ignition.. CLANK CLANK.. smh..But to answer your question Todd00, yes im thinking about keeping them. miles unkown...
Old Oct 16, 2013 | 05:26 AM
aw614's Avatar
10 Year Member
Loved
were they oem lug nut keys or aftermarket? If they were oem you could have just taken a picture and purchased the key from mcguard
Old Oct 16, 2013 | 07:04 AM
Thanks for the advice aw614. Its aftermarket lug nuts,and i will just replace them with new ones.
KPDSM
Acura TL, RL & ZDX
25
Oct 10, 2017 08:37 AM
ddorrisEF90
Aug 11, 2014 11:09 PM
turbo-2nr
Suspension & Brakes
Jun 19, 2008 05:50 PM
TrickHonda98
19
Jun 20, 2004 03:08 PM
92TypeR
May 15, 2002 12:35 AM
