oil pan problems - bolt holes in block stripped
Old Oct 12, 2013 | 03:45 PM
boostin1!'s Avatar
Default oil pan problems - bolt holes in block stripped
Hello, so m oil pan was leaking on my 96 civic d16y8 and first thing I did was try and toghten the oil pan nuts. One was loose and wouldnt tighten. I removed the nut and then the stud. And guess what there were all the threads from the block. So basically what should I do? Re tap it or try a bigger bolt? What would you guys recommend? Thanks!
Old Oct 12, 2013 | 05:43 PM
boostlsveg's Avatar
Default Re: oil pan problems - bolt holes in block stripped
Ur prolly gonna have to retap it slightly larger. If u wanna try a bigger bolt go for it but personally I wouldn't. I would check all the rest while ur there, n make sure u don't over tighten them or ur gasket will break and leak. They really don't have to b that tight. 9ftlbs is spec I believe, may b wrong on that tho.
Old Oct 12, 2013 | 05:51 PM
NZXTInerTia's Avatar
Helicoil.
Old Oct 13, 2013 | 08:44 AM
integrainside's Avatar
I would go for a helicoil if you can. I would consider upgrading to a stud kit while your at it and a better gasket. I was having oil pan problems for a while and finally got the http://myhondahabit.com gasket and it never leaked again. This setup was awesome and ended a big pain in the *** for me.
redred1188
Feb 18, 2020 06:20 AM
supadupafast
Aug 20, 2013 06:35 AM
lilpastrana
Mar 27, 2007 03:45 PM
90AcuraIntegra04
Jun 1, 2005 12:40 AM
fluke702
Feb 20, 2002 06:46 AM
