5 lug conversion on 95 gsr
I've read several threads regarding this but I'm still very confused. Can't I just swap over the parts from a usdm type r and use my stock axles? I know the usdm type r uses a 32mm hub. Also was wondering what parts have to be changed? All help is definitely appreciated!
USDM ITR=32mm axles. Same as any Integra.
Jdm CTR=32mm axles. Same as any Integra
Jdm ITR=36mm axles. Not the same.
Front knuckle assembly has to be replaced, rear trailing arms need to be replaced. Brake calipers and rotors as well.
You could just swap out all of the hubs instead of swapping knuckles/trailing arms. 99% of 5 lug setups are sold with Knuckles/trailing arms, it's just easier to swap the entire thing
jc2801
Jun 7, 2007 10:05 AM
RhdRicheeee
Nov 21, 2005 04:06 PM
