Ex exhaust into 98 Civic Lx question
Old Oct 11, 2013 | 12:21 PM
rosol16's Avatar
Default Ex exhaust into 98 Civic Lx question
I am looking to buy an exhuast for my 1998 Civic Lx but I cant find one anywhere I was wondering if I could get this exhaust and if it would fit on my Lx.
Honda Civic 2/4Dr Exhaust Catback System : Amazon.com : Automotive Honda Civic 2/4Dr Exhaust Catback System : Amazon.com : Automotive
Thanks in advance
Old Oct 11, 2013 | 12:52 PM
timbohonda's Avatar
Default Re: Ex and Lx 1998 question
Thats a good question. The fitment from Amazon indicates it fits. The description is very specific about what it fits only and does not include the 98 LX. I would steer clear if there's any doubt as you will pay return shipping. Talked with chat specialist and they said that this would definitely fit and not too much more than Amazon plus cool blue on the tip! Would you be able to check under the hood of your car in the engine fuse box and read the part number off of the heater motor relay? Located left of the cooling fan relay, mg clutch relay, condensor fan relay in that order. Really need that part number as my relay is missing!
Chat Transcript
info: You are now being connected to CARiD LiveChat. Please wait for a site operator to respond.
info: You are now chatting with 'Andy P - Ext 823'
Andy P - Ext 823: Hello, tim, my name is Andy P - Ext 823. How may I help you?
tim: will this fit the 98 Civic LX?
Andy P - Ext 823: Could you please give me the item number that you're looking at (it is 5-6 digits number right below the name of the product)?
tim: 12205977
Andy P - Ext 823: Please bear with me few minutes while I research on this product.
Andy P - Ext 823: Spec-D® - N1 Style Cat-Back Exhaust System with Burnt Tip (2.5" Inlet) will fit Honda Civic 1996-2000 LX model. Comes complete with hardware and gaskets. Price is $153.00+ shipping. I will be more than happy to assist you with placing the order to insure its faster and more accurate processing.
Andy P - Ext 823: Fits models from 1996 up to 2000.
tim: Great! Thanks!
info: Your chat transcript will be sent to timlexusgs300@hotmail.com at the end of your chat.
Andy P - Ext 823: You are welcome, is there anything else that you like to add to your order, Tim?
http://www.carid.com/1998-honda-civi...-12205977.html
Old Oct 11, 2013 | 05:21 PM
94EG8's Avatar
Seagull Management
It will fit if you run an EX manifold (or aftermarket header) and an EX catalytic converter. It also requires extending the wiring for the O2 sensors if you go this route (premade extension harnesses are available)
Old Oct 13, 2013 | 01:55 PM
rosol16's Avatar
Default Re: Ex exhaust into 98 Civic Lx question
So your telling me i cannot just buy this and bolt it on as is? I am not replacing the CC. I have stock LX 1998. The people at CarID said it would be guaranteed to fit. Also, if it wont fit what would I need to do to make it fit? Also if I was to replace the CC with this one http://www.specdtuning.com/mhf-cv92.html would it then fit because here it says that http://www.specdtuning.com/mfcat2-cv92.html the amazon one (same part #) would fit but only with cc?
Old Oct 13, 2013 | 01:56 PM
Former User's Avatar
Old Oct 13, 2013 | 02:06 PM
rosol16's Avatar
So I need the catalyst....
Old Oct 13, 2013 | 02:18 PM
94EG8's Avatar
Seagull Management
Exactly.
They lied to you or they're misinformed.
Or if you want to cut up a brand new exhaust you can cut the flange off the end, weld a length of pipe on along with a new flange to meet the downpipe. Or you could buy an aftermarket test pipe to give you the extra length. I don't like either of these two options, I don't like number 1 because I hate cutting up a new exhaust. I don't like number 2 because it introduces extra places for exhaust leaks and it just looks pieced together.
What you'll find is this exhaust ends up being roughly a foot too short where it bolts up to the downpipe due to the LX (and any model with the D16Y7 engine) having the catalytic converter integrated into the OEM manifold. The EX has it after the downpipe.
Sort of, it will fit however you'll end up with two catalytic converters one behind the other which is a bit restrictive and redundant. You can however use this cat along with an EX manifold or aftermarket header though as I mentioned in my first post.
If you're buying this exhaust with perceived notions of increased horsepower don't bother, especially with the extremely restrictive manifold you have.
Old Oct 13, 2013 | 02:24 PM
rosol16's Avatar
Dang seems like alot of work I was hoping to be able to just purchase and exhaust and be able to bolt it on it there any that you know of? or what is i bought this instead?
Honda Civic 2/4dr Ex Dx Lx Exhaust Catback System, Header, Test Pipe : Amazon.com : Automotive Honda Civic 2/4dr Ex Dx Lx Exhaust Catback System, Header, Test Pipe : Amazon.com : Automotive
gsr96cx
Sep 27, 2009 05:08 AM
xkrntamax
Feb 20, 2006 07:17 AM
CereaLand
Apr 14, 2003 09:40 AM
PolosportZ81
Mar 26, 2003 10:07 AM
