OBD II d15b non-vtec sensor question.
On the OBD II d15b non-vtec there are two sensors located directly below the heater core inlet hose. Both of the sensors are in the block. The single wire sensor is the temp sending unit for the gauge cluster? What is the other sensor? It is a two wire sensor. It is adjacent to the temp sending unit. It is not the thermoswitch for the fan as that is located on the thermostat housing.
CptHMCrunch
Sep 1, 2014 01:56 AM
