OBD II d15b non-vtec sensor question.
Old 10-11-2013, 07:56 AM
CptHMCrunch's Avatar
Default OBD II d15b non-vtec sensor question.
On the OBD II d15b non-vtec there are two sensors located directly below the heater core inlet hose. Both of the sensors are in the block. The single wire sensor is the temp sending unit for the gauge cluster? What is the other sensor? It is a two wire sensor. It is adjacent to the temp sending unit. It is not the thermoswitch for the fan as that is located on the thermostat housing.
The OBD II d15b non-vtec is going in a 1991 civic hatch with a rywire OBD0 -> OBD I jumper harness. The ECU is a p06. Does the engine that I am putting in the car have any sensors that do not need to be plugged in? This is what I was thinking as far as sensor that do not need to be plugged in.
Sensor: knock sensor
Status: not needed
Sensor: unknown two wire sensor
Status: not needed
If you have any information on problems I will encounter while putting this motor in the car please let me know as I am relatively new to motor swaps.
Thank you,
Cpt. HM Crunch
Old 10-11-2013, 08:14 AM
Keyboard Humorist
4drEF's Avatar
Default Re: OBD II d15b non-vtec sensor question.
any of these look familiar to your sensors?
Old 10-11-2013, 08:17 AM
Freemananana's Avatar
Status: not needed
Status: not needed
Okay, the Knock sensor isn't needed if your ECU doesn't have a knock board. The ECU you mentioned probably doesn't.
The 2 wire sensor next to the cluster temp sending unit is VERY NEEDED. I did a quick search for you.
Originally Posted by GhostAccord
The 2 wire one is the ECT sensor for the ECU and the single wire one is the temp sending unit for the dash. They are not the A or B fan switches. You will have a hard time running your engine without the ECT sensor and your dash temp gauge will not work without the other.
The ECT is very important and tells the ECU a lot from what I know. It needs to be hooked up. There is definitely a connection on the harness for it.
I know from experience, honda uses the same 2 wire plug for almost everything. Make sure you haven't swapped plugs on accident.
Old 10-11-2013, 08:18 AM
I believe what he is referencing is under the distributor. Next to the coolant temp sending unit for the dash cluster.
Old 10-11-2013, 08:26 AM
Keyboard Humorist
4drEF's Avatar
Ah - you are probably right!
I read heater core and assumed back of block.
Old 10-11-2013, 08:29 AM
Thanks for the picture though. That would have helped me so much when I was trying to figure out the sensors on the back of my block. Hardest part of searching is figuring out what other people call it.
I saw the sending unit and couldn't figure out what that one was called. It's weird the OP doesn't have the ECT plug just dangling there. Trying to figure out where he has that plugged in at.
Have you tried to start the motor at all?
Old 10-11-2013, 09:50 AM
jlicrx's Avatar
2-wire sensor has red/white and green/white wires
1-wire sensor has yellow/green wire
Old 10-11-2013, 09:58 AM
The motor is not installed in the vehicle yet, but you have answered my question. Thanks.
Old 10-11-2013, 11:19 AM
Yay! Now this thread will forever be solved and will help people who search for the same issue.
Old 09-01-2014, 01:56 AM
L14m_93's Avatar
Hi I've been lookin around online for a whole tryna figure this out I have the yellow/green wire just dangling around near my dizzy it doesn't have a plug on it at all just a single wire all alone I'm sure its always been like this I just taped over the end so it wasn't showing bare wire and everything was fine but now my temp gauge isn't going up at all and my fan won't kick in at all either speedo is also not working but the plug for vss is loose so i don't think its related, vtec won't engage either, ps I swapped a b16a into my ej9 not sure if this will make a difference but its got the same single yellow/green wire just dangling there without a plug on the end and I have no idea how to connect it.......
710dabber
11-05-2015 12:36 PM
CptHMCrunch
10-11-2013 08:16 AM
dishjuarez
10-14-2012 10:45 AM
foress_89
01-15-2008 03:58 PM
99-DC2
04-28-2004 08:39 PM
Quick Reply: OBD II d15b non-vtec sensor question.
