Clutch Slave Cylinder Alternatives?
2000 Accord, F23 engine with F23 transmission.
I'm running a heavy pressure plate which puts a high load on the clutch hydraulic system. After driving the car into town for a short while, the system doesn't fully disengage the clutch any more, making it difficult to get into and out of gears. It gets worse the longer I drive, but returns to working just fine after the car sits for a few hours and cools.
Is there a more robust alternative available; maybe a retrofit from another vehicle, or aftermarket cylinder? I might consider something with slight modifications or converting to a pull-type system if it helps.
Did we? My current option is to replace the rubber section of the line with a braided steel hose, and order new OEM master/slave. But I've run heavy clutches in the past and swapping these just seems to be an expensive band-aid.
I guess I'm not convinced it's an issue that replacing the line is going to completely resolve. I friend of mine is putting together an F2D setup which allowed him to switch to a pull-type setup with the slave cylinder, and that has me curious...
I might call them when they open tomorrow and see if they can put together a complete setup that will allow me to cut out the rubber section and install a braided line.
Any idea what the ID/OD of the stock hard line is for reference?
it's 3/16" OD on the civic. I can't remember if the accord uses a bigger hard line... we sold ours so i can't go check
. if it looks the same as the brake hard lines i would suggest it's 1/4" OD.
do you think it needs some added heat sheilding from the turbo/manifold? you could also try swapping the fluid for something more race-y and heat resistant, like DOT-4.
. if it looks the same as the brake hard lines i would suggest it's 1/4" OD.do you think it needs some added heat sheilding from the turbo/manifold? you could also try swapping the fluid for something more race-y and heat resistant, like DOT-4.
hYbRiD EeEkAy
Aug 7, 2008 11:27 AM
a1320addict
Feb 12, 2006 11:34 AM
