question about dizzy install
sup, need to install my dizzy but im not sure of the procedure
what i know but not sure: piston 1 at TDC, but must not be in compression(power) right? the rotor in the distribuitor must be pointing cilinder 1?
is it right?
thanks
is it right?
thanks
See the slot in the end of the exhaust camshaft? It's slightly off-center. There's a tab on the distributor shaft that's also slightly off-center. You turn the distributor shaft so that the off-centers are on the same side, and install the distributor. Tab will go into slot, and you're done.
If you've got it lined up right, the distributor housing will sit flush against the head. If it's not flush, DON'T JUST USE THE BOLTS TO FORCE IT HOME! Recheck your tab/slot alignment and try again.
Adjust the ignition timing after the distributor is hooked up again.
racekar
Oct 19, 2004 09:32 PM
