1994 Honda Accord Ex Temp Issue.
Old Oct 8, 2013 | 07:43 PM
acso24's Avatar
Default 1994 Honda Accord Ex Temp Issue.
I just bought a 1994 Honda Accord EX with a 2.2 4cyl manual Transmission with the Head Gasket blown. I replaced the Head gasket and was looking for the cause of the initial overheating issue. I changed the thermostat flushed the radiator. I am at a stand still. When the vehicle idles after running for awhile the temperature guage slowly rises but when it get above half the fan kicks on and brings it back down. Is there still an issue with it over heating, or should it be fine?
Old Oct 8, 2013 | 10:41 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 1994 Honda Accord Ex Temp Issue.
Use this link and test your cooling system. http://techauto.awardspace.com/overheating.html
Old Mar 9, 2014 | 07:05 PM
Jimmydean771's Avatar
It sounds fine, but check the water pump for leaks. F22B1s are bad about water pumps going out.
shawn323
Jan 17, 2013 12:41 PM
kevinp1
Jun 30, 2012 06:47 PM
AzHondaPhx
May 10, 2012 05:30 PM
chiaxi2002
Apr 20, 2009 09:31 AM
PREACHERBREW
Aug 19, 2006 01:18 PM
