Transmission & Drivetrain Gearboxes, Differentials, Clutches
'97 Accord A/T stuck in park except w/key
Old Oct 8, 2013 | 05:41 PM
some1onen's Avatar
Default '97 Accord A/T stuck in park except w/key
I have to use the key in the console keyhole (positioned just right of shifter) to get out of park. Will this persist after brakes are bled? Assuming problem is related to busted/replaced brake hose & fluid...
Old Oct 8, 2013 | 07:19 PM
grjr's Avatar
Default Re: '97 Accord A/T stuck in park except w/key
brake hoses/fluid have nothing to do with the parking solenoid. To start with a problem like that you may want to check that the brake pedal switch(es) are working with a multimeter.
Old Oct 9, 2013 | 09:58 AM
some1onen's Avatar
@grjr- Thx! Will post update after the rains...
Old Oct 9, 2013 | 02:31 PM
jdmh22eg2's Avatar
most likely its a solenoid under shifter console attached to shiter cable or to the shifter assembly
Old Nov 5, 2013 | 01:52 PM
some1onen's Avatar
Icon6 Re: '97 Accord A/T stuck in park except w/key
Update:
Sooo: Must be Coincidence that the brake line and brake lights/sys act up simultaneously... I have now burnt thru four 20amp fuses after replacing the busted brake hose & bleeding the system. The 'Horn/StopLite' fuse replacement unlocks the shifter & the lites work for an unknown time/sequence/number of braking events. Before I reach my destination, the brake lites have failed and I will be stuck in Park (unless I leave it in neutral with the parking brake...).
I b check the pedal switch and console solenoid now and replace the 20amp fuse again. Thanks & will update again soon!
Old Nov 5, 2013 | 06:15 PM
grjr's Avatar
Has the car ever been in a accident? If it has I'd be checking the wiring harness near the taillights and wherever your horn is located. If you have a fuse repeatedly burning out then it is likely an intermittent short to ground which can be caused by damaged insulation on a wire shorting it to ground. If you're not finding anything unusual you're going to need a wiring diagram for the car and a lot of patience to find what is causing your problem.
Old Nov 25, 2013 | 04:51 PM
some1onen's Avatar
Finally! grjr: The trailer wiring was the culprit! Homey removed the trailer wires & reported there were some very suspicious connectors. Five 20-amp fuses later and all is well!
Thanks very large!
thrasherx
Jun 23, 2024 04:22 AM
oohtruck
Sep 17, 2012 08:46 AM
puppetmstr80
Aug 26, 2005 11:43 PM
tom5683
Nov 16, 2004 07:43 PM
