16" rims on lowered Eg civic?
Hi guys, I've got a 95 Civic Si hatchback lowered 2.5" on dna motoring coilovers, and I'm currently sitting on 15" Drag DR-21's wrapped with Dunlop Direzza DZ101's 205/50R15 for tires although I'm just not happy with the way my car is sitting. I've been searching online and found a set of XXR 531. They are 16x8 with a +20 offset. I'm wondering if these will fit my car without having to camber? I realize I will most likely need to roll the fenders, I just don't want to camber the car mainly because I've never been a huge fan of it. And if they will fit, what size tire would you reccomend? Anything will help! Thanks a lot!
Anything past a 7" wide wheel with +32 offset will require either fender rolling/pulling, negative camber, or some form of tire stretching.
So, in your request, you would definitely need a little bit of negative camber and tire stretching.
Thanks, this helps a lot! So would I need to camber the car to the point where it looks very noticeable? I have seen them where they had a slight camber, and the look was fairly clean rather than having some ridiculous 45 degree angle. Do you have any recommendations on how much camber?
Ej1SIR
14
Oct 7, 2009 01:27 PM
98savage
Suspension & Brakes
20
Oct 25, 2008 06:31 PM
*Boostwerks*
Feb 27, 2004 10:46 AM
