98 civic hatch whats available?
Old Oct 7, 2013 | 11:00 PM
raverx3m's Avatar
Default 98 civic hatch whats available?
I just got a 98 civic hatch CX model
planning to make it a somewhat decent daily driver...
whats available for it?
leather seats from other cars?
black interior? or is it all grey
projector headlights with separate high and low beam or all have dual beam single bulb?
I assuming that the center console can be switched to a double din from newer model ek?
what I gathered from a bit of research
d16y8 is best power single cam available
boosted single cams can get 40-50mpg ( is that possible with any Bolton turbo kit or custom only?)
what about using an MR2 supercharger that has a pulley that can be disengaged?
Old Oct 8, 2013 | 05:54 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Default Re: 99 civic hatch whats available?
Search around in some build threads, this has all been answered before.
Old Oct 8, 2013 | 06:31 AM
CO671's Avatar
Originally Posted by raverx3m
I just got a 99 civic hatch CX model
Leather seats from other cars?
Originally Posted by CO671
~$??? - Seat Swap
More Info
96-00 CIVIC:
-Front-
•92-95 Civic w/EK rails
•94-01 Integra w/EK rails
•97-01 CR-V w/EK rails
•92-97 Del Sol w/EK rails
•97-01 Prelude w/EK rails
•97-02 Accord Coupe w/EK rails
•01-03 CL w/EK rails*Requires 12v for heat feature
-Rear-(Hatch)
•92-95 Civic *Hatchback only
•94-01 Integra *Hatchback only
•02-06 RSX
-Rear-(Coupe)
•01-05 Civic Si*EP3 only
-Rear-(Sedan)
•92-95 Civic Sedan
•94-01 Integra Sedan
Black Interior?
TYPE F = Excel Charcoal / Light Gray
TYPE K = Classy Gray / Dark Gray
TYPE P = Medium Taupe / Tan
source: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/help-96-00-interior-colors-1959549/
Do your own projector retrofit and you can figure that all out from there, better to have dual beam single bulb iirc. Do more research into that, I don't know much about lighting.
What do you mean by this?
A blockoff? Newer model EK? Can you elaborate?
Pay attention to the FAQ
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faqs-frequently-asked-tech-questions-1998336/
Stock-wise, yes. Build wise, it's usually between the Z6 and the Y8 when it comes to D-series builds.
Boosted single cams with stock internals (primarily the connecting rods) can reach around 210 (more or less) TUNED (chipped & tuned ECU) with a reliable turbo and proper setup. Any more than an average 210 hp the rods are believed to blow rendering the engine useless until a rebuild.
edit: I just realized you probably know tons more than I do, so ignore this....
When it comes to turbocharging. Essentially, the main piece that would be specific to a car would be the turbo manifold. Everything else is generally universal. Turbocharger itself, intercooler & piping, oil lines, etc. Injectors, aftermarket fuel pump, intake manifold swap and OBD1 conversion should be considered when turbocharging a stock D-series. DO RESEARCH. There's LITERALLY Thousands of threads online of the same question and information.
These are just from the FAQ, not to include info from other websites.
Look it up, chances are you won't get a straight answer in this thread.
What would I recommend immediately?
-Full service/maintenance. All fluids, replace worn bushings or serviceable parts.
-Ensure everything's adjusted to spec. Pedals, throttle cable, valve lash, suspension aligned, tires balanced, engine is mechanically timed properly, as well as the ignition timing.
-Once reliability is all set, look into cheap mods. I prefer to start with the basics:
Dome Light, (Integra DIY) Short Shifter & Weighted Shift ****, wide angle rear view mirror
Front seats, I'd keep my choices between a 92-94 Prelude, 97+ Integra, or whatever OEM seats you find more comfortable that you can find for cheap. I have CRV seats in my Civic (has drivers armrest if found from 97-01 Automatic CRV's) and it's similar to 99-00 EM1/SI seats. I honestly think it's a tad better than stock Civic seats but has no lower back support. The best and cheapest mod I've ever put into my Civic is a pillow for my lower back.
Then look into suspension, rear sway bar, coilovers.
FAQs - Frequently Asked (Tech) Questions
6th Generation FAQ
WARNING: BEFORE ADDING MODIFICATIONS, SPEND YOUR MONEY ON NECESSARY REPAIRS.
Please, do the roads, safety of other people, your car, & yourself a favor by fixing any problems with it now.Before you plan on slapping on some accessories or modifications, ensure your vehicle is safe, reliable,& sturdy. An overall tune-up would be the best modification if the vehicle hasn't been maintained properly. This may include all fluids (oil, antifreeze/coolant, transmission oil, brake, &/or power steering, & clutch). A distributor cap, rotor, or spark plug + wire change too, suspension bushings, brake pads/rotors etc;. You get the gist, just make sure your vehicle fits spec reliability before you do anything, or else your car will just be riced junk with accessories.
IF YOU HAVE A D16Y7/D16Y8 ENGINE AND YOU WANT TO DUMP $1000's INTO HEADERS/INTAKE/EXHAUST FOR "POWER" YOU'RE WASTING YOUR TIME. YOU'RE BUYING SOUND MODS, NOT POWER MODS. THESE ARE ECONOMICAL ENGINES FOR GAS MILEAGE, NOT HORSEPOWER. THERES NO HIDDEN POTENTIAL POWER FOR AN ALL MOTOR BUILD, DYNO RESULTS PROVE THAT THEY GIVE NO NOTICEABLE POWER WORTH THE MONEY. . SO READ THE LINK BELOW UNDER "ENGINE".
I. Interior
-Integra Dual Bend Shifter
-Weighted Shift ****
-Wide Angle Rear view mirror
-Dome light LED upgrade
-Integra/Civic EX/SI Map light
-Seat Swap
-Cluster Plug&Play
>>Clusters requiring modification
-Steering wheel swaps
-Headliner/Carpet Dye
II. Exterior
-Front Lips
-Rear Lips
-Mudguards
-Fog Lights
-Tail Lights
III. Engine
IV. Suspension
V. Wheels
Interior
~$20+ (usually under $20) used Integra dual-bend shifter into 96-00 Civic
(Will need to be cut/dremeled to fit)
I highly recommend this, a noticeably different feel /short throw and worth the effort.
Length to cut
Shifter Installation Tutorial
~$??? weighted shift ****
If you want a different feel in shifting but don't want to do the shifter mod mentioned above, purchase a weighted ****. I personally use the PWJDM and it makes a huge difference.
~$25 240mm Convex Broadway rear view mirror (Ebay/Amazon)
If you're not a fan of a Convex, then a flat version is available.
~$5 48-LED panel Dome Light insert
Amazon Listing - All Bulb Sizes for Civic
~$??? used Integra/ Civic EX or SI Map-Light DIY
Integra Map Light - Map + Trunk Light Tutorial -
~$??? - Seat Swap
More Info
96-00 CIVIC:
-Front-
-Rear-(Hatch)
•02-06 RSX
-Rear-(Coupe)
-Rear-(Sedan)
•92-95 Civic Sedan
Cluster Modifications
Any 96-00 based Civic chassis cluster will plug & play no modification, this applies internationally.
Japanese, European, Asian, Australian/New Zealand, Canadian clusters will fit in USDM Civic's too.
97-01 CRV's - JDM Honda SMX - CDM (Canada) Acura 1.6 EL - Isuzu Gemini - Honda Orthia - JDM Honda Integra SJ also
Modification Required Clusters:
94-01 Integra
03-04 Civic
S2000
~$??? Steering wheel swaps
"What OEM Wheel fits w/ tutorial links"
~$?? Headliner/carpet dyeing (can be reupholstered easily too which may be better)
Carpet
"Post Your Interior Thread" (For Inspirational purposes)
Exterior
1996-1998 / 1999-2000 Civic Body Differences & Front & Rear Conversion
96 - 98 Lip Options
If purchasing a replica lip, do yourself a favor & get a polyurethane replica, they're much more flexible than the ABS plastic which may crack & break very easily, although their fitment may be more precise (not as precise as OEM or genuine of course)
99 - 00 Lip options
Info: When it comes to replica 99-00 front lips, the OEM 99-00 front lip is the same as the Civic Type R, & the 99-00 EM1/SI coupe front lip. so... CTR = Si = OEM.
You can tell the difference between an OEM/CTR/SI front lip, & a replica version because the replica has more flare on the sides & extends further than the OEM/CTR/Si. It's obvious if you focus.
Same applies as mentioned above for the 96-98 replica lips purchases & quality.
Rear lips:
Info: There is a difference on rear bumpers between the years & models.
96-98 Coupes/Sedans share the same rear bumper
99-00 Coupes/Sedans share the same rear bumper
96-00 Hatchbacks share the same rear bumper
Mudguard options:
Front mudguards:
FOR COUPE = Any '96-'00 Civic mudguards will fit.
FOR HATCH = Any '96-'00 Civic mudguards will fit.
FOR SEDAN = Any '96-'00 Civic mudguards will fit.
Rear mudguards:
FOR '96-'98 COUPE = '96-'98 Civic coupe/sedan mudguards fit.
FOR '99-'00 COUPE = '99-'00 Civic coupe/sedan mudguards fit.
FOR '96-'00 HATCH = '96-'00 Civic hatch mudguards fit.
FOR '96-'98 SEDAN = '96-'98 Civic coupe/sedan mudguards fit.
FOR '99-'00 SEDAN = '99-'00 Civic coupe/sedan mudguards fit.
Rear RSX mudguards have been cut to fit rear bumpers with rear lips on hatchbacks.
Fog Lights options
96-98 Circle - 96-98 Square
99-00 Circle
DIY 96-98 Civic square fog light wiring tutorial
DIY 99-00 Civic Ebay Fog Light Wiring tutorial
Info: In the US, USDM (OEM) Fog-lights came in clear lenses. The OEM Brand for Honda fog-lights would be "Raybrig" or "Stanley". Another common brand is "Depo" which are replica aftermarket foglights. They tend to leak, & install/fitment won't be 100% as OEM, so be aware you get what you pay for. Esuse is another aftermarket brand, of higher quality than Depo though.
Also, for the 99-00's, the OEM ones came with (as mentioned before) clear Raybrig lights, & a gray cover like this. Often, you may see yellow lights & a black cover, as that's usually the "JDM" ebay/replica aftermarket version. P.S: PWJDM Lights are Depo brand, not OEM. This is because in Japan the 99-00 lights are yellow Stanley's from the factory. As an aesthetic option, you can always get clear foglights & tint them with yellow tint, if you decide to change your mind, you may remove the tint & go back to clear fogs.
Tail-light options:
They're separated into different categories as to what matches the body, the coupes & hatcbacks are interchangeable in all years. however the sedans have two different trunks depending on the year.
96-00 Coupes
96-98 OEM Amber - 99-00 OEM Non-Amber - 96-98 Red tint over amber - 99-00 Smoked over Clear
96-98 Sedans
info: (need clarification) 96-98 Red/Clear Depo's are replicas of the 96-98 Red/Clear JDM SiR/Honda Integra SJ
96-98 OEM Amber - 96-98 Red/Clear JDM SiR/Honda Integra SJ
99- 00 Sedans
info: 99-00 Red/Clear Depo's are replicas of the 99-00 Red/Clear Philippine SiR/Honda Integra SJ
99-00 OEM Amber - 99-00 Red/Clear Philippine SiR/Honda Integra SJ
96-00 Hatchbacks
96-98 OEM Amber - 99-00 OEM non-Amber - 96-00 Clear Hatchback Aftermarkets
Engine
A clean sweep for a first, WD40 and/or simple green/engine degreaser and a pressure washer or just simple a hose does a great job. Make sure you cover electrical components though.
If you have a D-series and want to modify the engine for power, but don't have at least $2,000 to spend, you should just give up and save up until then. Read this thread for more info:
Guide to Answer the Common Question: Just Bought a Civic! How Do I Make It Faster?
~$20 Valve Cover Painting
DIY
Suspension:
All that would be said here is if you go cheap, you get cheap. Suspension is crucial to your safety.
In most cases, when referring to Civics coilovers, the coilovers would be a whole aftermarket kit (shocks + springs combo [adjustable or not]), Shocks being just the shock absorbers, and springs/coil sleeves being the springs that are wound around the shock.
Lowering springs w/ stock shocks: Bump stops may need to be cut in half + dust boot (get alignment, shocks may blow)
Adjustable springs w/ stock shocks: Bump stops may need to be cut in half+ dust boot (get alignment, shocks may blow)
A great option to refer to is a rear sway bar, this reduces body roll and helps increase handling. If you feel like you're falling out of your seat in a deep turn, tires slipping, car feels like it's twisting, then get a stabilizer/sway bar and chances of that will decrease, I wish I had purchased a rear sway bar as my first mod.
EK Honda Civic Coilovers Install
The common answer to be the best bang for buck suspension setup,would definitely be Koni Yellow/Ground Control combo. More info here:
Need help choosing suspension? Click here!!
Wheels:
You have a many options as long as they fit your bolt pattern (commonly 4x100 unless a lug-conversion has been done)
OEM wheels, a replica knockoffwheel along the lines of (XXR. Drag. Rota etc or the more genuine brands such as Work, CCW, SSR, Mugen, Rays, Enkei, etc;.
14's seem to small, 17's are pushing it for the big side (the rice days are over)
Keep your range between 15 & 16 with good tires.
Inspirational / Picture Threads:
Show off your 6th Generation Honda Civic (1996-2000)
** The offical 96-00 civic 4dr thread ** PART 2
***POST ALL SILVER EJ6, EJ8, & EM1 COUPE***
Calling all BLACK 96-00 Civic Coupes!
Post your rare 96-00 Civic parts
Post Up Your LCA's & Exhaust pics.
**The Official RAYS Volk Racing Wheel Thread**
**OFFICIAL ENKEI WHEELS THREAD (RPF1, 92, J-Speed, etc...)**
All Sportmax & XXR wheels, Post them here.
Post your CCW wheels
Low Offset Wheel Thread
Official Konig Wheel thread
-=Official SPRINT HART Wheels thread=-
♠ Shaved, Tucked, Customized Engine Bays - Pics, Theory, Discussion ♠
Post Your DIY Door Panel Inserts!!!
*!*!*Civic's w/ SiR bumper moldings*!*!*
Old Oct 8, 2013 | 07:55 AM
b20hatchek's Avatar
now that was a bada** answer ^^^
Old Oct 8, 2013 | 08:46 AM
raverx3m's Avatar
Dafuq . Lol
I must have all the clusters now...
Wasnt asking for that much info but thanks.
See i cant get real spoon so i get spoon fed
Old Oct 8, 2013 | 11:21 AM
nismoracingsx's Avatar
lol, i just bookmarked this thread ^_^
Old Oct 8, 2013 | 01:41 PM
raverx3m's Avatar
I built all motor gsr once lol.
Dont know much about boost
Just red few people claiming some good mpg with boosted cars which makes sense from what i know.
Old Oct 8, 2013 | 03:31 PM
Marvin1985's Avatar
Mother of all post replies.......
Old Oct 8, 2013 | 03:34 PM
CO671's Avatar
Dafuq . Lol
Wdf? haha show your collection!
Yeah, I'm used to just compiling a **** ton of info for noobs and just throwing it at them to see what they're gonna do next (in most cases, they ever log back in, or they totally just go into the ricey or stance scene ignoring my suggestions )
Took me a while to realize you know your Honda's actually and a member since 2005. Hell, I was only 10 at the time.
lol, well can you elaborate about the center console thing though?
At least you're mechanically inclined and exposed to the forums enough!
Turbocharging doesn't make it any great because you are upgrading the fuel system so as long as you tune a good AFR I assume it would be decent mpg, not 50+ of course... I'm not too sure about this all though, I just got into tuning Subaru's recently and it's hella confusing.
Check d-series.org for all the info about turbocharging a D, it took me a couple days to fully grasp the concept of turbocharging and all, but in the end after all my research I finally understand what I need to do to get it all together.
Old Oct 8, 2013 | 04:26 PM
raverx3m's Avatar
I just got the car didn't have time to do much more searching than I did...
the ej comes with slider heater controls
I see the other ones with a double din opening and round buttons on the side
my dash
dash that I want
Old Oct 8, 2013 | 04:39 PM
CO671's Avatar
I thought you said you got a 99 Civic hatch?
If you have that one on top then you most likely have a 96-98 Civic... Unless the previous owner did a complete 99-00 to 96-98 climate swap in his 99-00, which is incredibly more difficult than a front end body swap.
Old Oct 8, 2013 | 04:41 PM
01-0720's Avatar
the dash you pictured as yours is from a 96-98 but you said your car is a 99,, the one you pictured as the one you want is from a 99-00
if your car really is a 99, then someone went through alot of work to convert your dash to 96-98 specs, it isnt easy as just replacing the dash piece, the whole internal hvac controls are different, 96-98 uses sliders, and 99-00 is electronic with buttons
so is your car really a 99?
leather seats,, you can use S2000 seats, or dc integra front seats, you can use the s2000 or integra seat rails to, you dont have to switch to ek rails,, the only thing you need to do is slightly mod the rear inner seat mount, the hole doesnt exactly match up, on the integra seat you need to make the hole larger, the s2k you need to drill another hole, very easy,, and both seats will sit a good bit lower the stock civic seats
the integra leather seats come in black or dark grey
the s2000 leather seats come in black, red, blue, tan, red/black
for rear leather seats, you use 2 door dc integra upper section, you swap the leather cover and cushion onto the civic frame,, and you use 4 door db integra bottoms, and they will bolt in a fit flush, cant use 2 door dc bottoms
the jdm ek9 civic type r came with a oem black interior, of course the dash is rhd so you cant use that, but all the rest of the interior will swap in, and you can get vinyl dye SEM to get the dash to match
for projector headlights there are many aftermarket companys out there that make them, just do a google search and many will come up
and there are many turbo kits out there, to get it to run right and still get good mileage you will need a good way to tune it, ie hondata etc, but yes you can still get great gas mileage with a turbo kit, just keep the turbo small
Old Oct 8, 2013 | 06:10 PM
crazyhouse2011's Avatar
Supercharge that b*tch. Be different. I would imagine it would be easier than turbo.
Old Oct 8, 2013 | 06:31 PM
CO671's Avatar
Not only did the EK9 come in black interior, but there are some EDM LHD Black interiors, however the dash alone is a hefty price (i believe its the EK4 VTI)
Some people ask up to $1000+ just for the dash... another option is to dye, but that's too much work. I think the Type K Dark gray is fine.
ie:
Old Oct 8, 2013 | 07:15 PM
raverx3m's Avatar
sorry it is a 98 I didn't realize that I made a typo.
Old Oct 8, 2013 | 09:24 PM
raverx3m's Avatar
is this even worth putting time into? its the cheapest version guy bought it for like 13000 brand new from dealer and theres nothing power no windows or mirrors...
Old Oct 8, 2013 | 10:07 PM
CO671's Avatar
It depends what you want. Its the lightest Civic chassis stock, the 98 CX hatchback weighs at 2300lbs
Old Oct 26, 2013 | 10:11 PM
raverx3m's Avatar
have few questions after searching and not finding much
are there any other stock radios available for 96-98 civic dash that have a cd player maybe?
what seat options were available for the 96-00 hatchback
on the 98 models with that stupid trunk lock was there a power lock/unlock option?
i know cx didnt come with anything power but DX did. did it have power lock for the trunk?
Old Oct 26, 2013 | 10:45 PM
CO671's Avatar
Just check crutchfield for some headunits that fit in a 96-98
I mentioned DIY seat options in my above quote, scroll back up! Other than that, USDM hatches only came in the shitty seats.
Old Oct 27, 2013 | 09:56 AM
raverx3m's Avatar
Yea i know about from other cars. Ive been looking for some
What about the dx hatch is there a power trunk lock?
Old Oct 28, 2013 | 09:10 PM
raverx3m's Avatar
and again alot of those posts that everyone keeps linking to
DONT HAVE THE ******* PICTURES ANYMORE!!!!!!!!!!!!!!!!!!!!! THEY ARE USELESS!!!!
in other news
is there a leather wrapped steering wheel for 96-00 civics? i havent seen one in person what year/trim they came from?
Old Oct 28, 2013 | 10:08 PM
CO671's Avatar
in other news
Which links are you talking about? I can try to find an alternative
what kind of leather? Anything specific? Like stitched red or just plain black?
If you want to keep it OEM look up any of the steering wheels mentioned in the link that I had already posted above
https://honda-tech.com/forums/showthread.php?t=2842882
98-02 Accord
03-07 Accord
08-10 Accord
03-07 Accord Euro R
96-00 Civic (377mm diameter)
01-05 Civic
06-10 Civic
97-01 CRV
96-00 Domani
97-00 EL
01-05 EL
01-08 Fit
09-10 Fit
99-06 HRV
00-06 Insight
97-01 Prelude
99-09 S2000
02-07 RSX
03-07 TSX
Old Oct 28, 2013 | 10:31 PM
raverx3m's Avatar
alot of the older writeups are missing pictures. regardless of what section they are in.
if HT would host the damn images even in half the size there would be much less questions asked by noobs.. but i dont see it happening any time soon.
i just want a stock steering wheel. im not trying to spend tons of cash on this car.
lowballers gnna lowball. i spent 12000 on my del sol and now cant even sell it.
people are so fn cheap. i buy a used part for 250 it sits on my shelf and when i sell it people claim that somehow its more used than it was before so its worth less. like it matters which shelf it sits on warehouse or my garage.
ive seen few pictures of 96-00 leather steering wheel but not sure what year and trim it came with and if its even available in dark grey.
Old Oct 28, 2013 | 10:39 PM
raverx3m's Avatar
oh and the reason i wanted stock radio is because it sits flush with the heater console.
i hate aftermarket stereos look they only look good on the store display but almost never blend in with the cars interior
Old Oct 29, 2013 | 11:36 AM
estewar03's Avatar
I know the feeling about the lowballers out there. I can't stand when I'm selling something for like half what it costs online and people still try to get it for less, bastards...
As far as the steering wheel goes just get one from a canadian acura el, I dont know if they are in grey though, I thought you were switching over to black interior anyways?
