testing a map sensor without a vacume pump??
Old Oct 7, 2013 | 10:34 AM
hillbillycivic's Avatar
Icon2 testing a map sensor without a vacume pump??
my car is still running rich even with its new o2 sensor. about -2 to -5 both short term and long term at idle and gets higher wile driving or accelerating up to -10 wile crusing at 3k rmp in 4th.
iv read online to check the map sensor. can some one help me out with this i have a multi meter but no vacume pump is there any standard reading it should be at at idle and under throttle in neutral?
i unpluged the conector from the sensor and one pin is 0 volts(guessing ground) and one pin is 5.07 volts (guessing power) but the other is 4.8 volts... im asuming signal but should that one even have a signal voltage if its unpluged?
either way i put some back probe pins in the conector and it read about .8ish no throttle and up to 2.8ish when snaping the throttle open.
Old Oct 7, 2013 | 05:03 PM
grdy98's Avatar
Default Re: testing a map sensor without a vacume pump??
might help out or point you in the right direction
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/map-sensor-test-1998-civic-done-correctly-3004860/
T-nastyteggy
Apr 20, 2011 08:37 PM
go'in crazy
Aug 27, 2009 12:42 PM
AVATAR
Dec 14, 2002 05:14 PM
comptechgsr2000
May 8, 2002 03:53 PM
