h22 swap shift linkage issues.
Old Oct 6, 2013 | 02:00 PM
toki's Avatar
Default h22 swap shift linkage issues.
I have a 95 coupe with a 94 h22a swap I've had this car for 4 years and haven't had much issues. Until one day one of my shift cables break, I order another set on eBay and they are 2.5 inches too short, then I find a 92 accord and pull the linkage myself and I get home and the same problem it also is shorter than my original linkage by 2.5 inches. From what I read online 90-93 accords and 92-96 preludes all use the exact same linkage!!! I don't understand this at all.
Old Oct 6, 2013 | 07:51 PM
Bently_Coop's Avatar
Steve at Heart
Default Re: h22 swap shift linkage issues.
Go to a Honda parts website like Majestic and cross check the numbers to verify differences. I would go from there. Maybe the 97+ preludes have longer cables.
Did you pull the cables off a h22 prelude or f series? No sure if it matters though.
Old Oct 7, 2013 | 04:22 AM
toki's Avatar
I originally bought the car in 09 already h swapped with a blown engine, I replaced engine and went on my way. So I have no idea where the original came from, the first replacement was from eBay and said it works with accord prelude or h swap civic, it was too short, then I pulled one from a f series 92 accord. They were both the same length, 2.5 inches shorter than my original.
Old Oct 7, 2013 | 04:24 AM
Fliptard's Avatar
are you routing the cables the same way?
Old Oct 7, 2013 | 09:48 AM
toki's Avatar
Yes. There's only one way for it to go. But I actually laid both of my replacements side by side along with the original and the original looks exactly the same but is 2.5 inches longer than the 2 I've purchased. Looks like I have 2 options find someone to fix my original somehow or cutting and moving the whole shifter assembly forward 2.5 inches. I'm leaning towards recutting and welding the shifter assembly position, I have enough clearance... What do you guys think?
Old Oct 8, 2013 | 09:47 AM
slowredsol's Avatar
Which cable you need depends on which shifter you have. (Prelude, accord) and the year of the lude or accord the shifter came from. You could have a 94-97 accord shifter.
Old Oct 8, 2013 | 09:51 AM
slowredsol's Avatar
Which cable do you need? The one that is stationary? Or the one that operates the shift lever? Can you measure it and see how long it is? I have several cables from different accords and ludes and I can tell you which one you need.
Old Oct 10, 2013 | 07:10 AM
toki's Avatar
I can only shift into 2, 4, and R. So the one that differentiates between "up" and "down" gears. Do u want a measurement of just the cable part or the entire linkage?
Your Avrg Joe
Transmission & Drivetrain
Aug 6, 2013 02:45 PM
h23vtecpowered
Oct 25, 2007 02:26 PM
redlude04
Nov 27, 2004 04:55 PM
JSR
Oct 7, 2004 12:15 PM
F120man
May 13, 2003 06:46 AM
