best cams for a dd setup
i want a cam that's better than the ctr or itr for my DD want a good power band and a vtec point similar to the gsr
b18c1 block
b18c1 rods
pr3 pistons
b16b head
blox intake
blox dule valve springs
blox flat valves on the ex
68mm TB
4to2to1 hedder
2.5 stealth thermal hedder back
b18c1 block
b18c1 rods
pr3 pistons
b16b head
blox intake
68mm TB
4to2to1 hedder
There's no 'best cam'.
Since you already have a bunch of Blox stuff, maybe check out the Blox Type Cs. It's an exact replica of the Jun III cam and it makes really good power on motors like yours.
Otherwise the Skunk Pro series will make great midrange, or maybe a custom grind from DDtech. Kinda depends what you're looking for. But if it was my motor i'd probably match the valvetrain with the cams if possible.
I would do some research and see what people have had success with man. We get flooded with this same thread every week, so please - read the top sticky threads and go from there.
ive got a canoe, life jackets and fishing poles. bring the bait and some beer!
op- i take it you plan on getting this tuned to some extent.
i went with type r cams on a similiar build. they are borderline too small and dont make gobs of power at 8500 rpm, but they come on nice in the 5000 rpm range right after vtec.
there is a TON of info on this, **** i searched around for weeks before making my decision. you have some reading to do so get at it
i would like to make around the same power as the type r
mugen4door
47
Oct 13, 2013 08:37 AM
5.0 Killa
68
Dec 7, 2011 08:23 AM
