Hellaflush Toyota 4runner
Well the race car is torn apart, and I'm bored and out of argon for the TIG, so here are some pics of my daily driver. Bought it last year completely stock, and finnished the suspension/armor within a month and wheeled the **** out of it, and I just recently finnished the turbo setup for it, just need some extra time to throw in the built long block and see how it does. Anyways here it is.
1996 4runner SR5, 213,000miles, 3.4l V6, Automatic
Suspension:
Trail Gear Tacoma Kit C
3" Leaf Springs
Frenched Rear Shackle Mount
5125 Bilstein Shocks
Front Frame Reinforcement Plates
Tacoma High Steer Kit
Six Shooter Knuckles
ARP Knuckle Studs
86-88 IFS steering box
T100 Oil Pan
Power steering hose conversion kit
FJ60 Donor Axle for extra Parts
Axles:
Rock Assault™ Front Axle Housing
Dirty 30s™ 30 Spline Chromoly Birfield/Axle Kit
Rock Assault™ Rear Axle Housing
4340 Chromoly Rear Tacoma Axle Shafts
High Pinion 3rd's With 5.29 Grears
Front/Rear ARB Air Lockers
Wheels/Tires/Brakes:
37X12.50R17LT Maxxis Trepadors
Pro Comp 98 Rock Crawler 17x9 Wheels 2.5" Backspace
Tacoma Rear Disc Brake Setup w/ Braided Lines
FJ60 Front Brakes w V6 Calipers & Vented Rotors
DriveTrain:
23 Spline 2.28 Input Gear
Trail Creeper™ Tacoma Dual T-Case Adapter Kit
95 4Runner Speedometer Sensor
Northern Colorado Driveline front and rear CV Driveshafts
Transgo A340 Race Valve Body
Hayden Transmission Cooler
Armor/Recovery:
Rock Defense™ Tacoma Dual T-Case Crossmember
Addicted Offroad Front Bumper
Addicted Offroad 68" Heavy Duty Sliders
Addicted Offroad Custom "Lambo" Rear Tire Carrier
Lil 'Skips Offroad #rd Gen Gas Tank Skid
Smittybilt XRC8 Comp Winch w/ Synthetic Rope
1st Gen 4Runner Roll Bar for storage and mounting
Lighting:
2002 4Runner Clear Housing Headlights
FX-R Bi-Xenon HID Projector Retrofit w 5000k Bulbs
Single row 72w LED Light bar
CREE Led Reverse Bulbs
7- 10w LED Rock Lights
LED Interior and Dash Lighting
Performance:
52Eighty Performance and Fabrication 5VZFE Turbo Kit-
Custom stainless steel turbo manifolds(1.5" Primarys) with true 2"crossover pipe and merge collector
Precision Billet Wheel PTE 5557 T3/T4 Turbo, TO4SP Compressor Housing, .64A/R Exhaust Housing
3" full stainless downpipe and exhaust with High Flow Cat, and Dynomax Muffler
44mm Billet GSP Wastegate with 4psi Spring
2.5" Intercooler Piping with front mount Intercooler
Tial 50mm Blow Off Valve
4" Intake with K&N Cone Filter
DEI LavaRock Wrap On Hot Pipes
AEM FI/C Engine Management w/ MAP Sensor
Custom AEM Wire Harness
AEM Wideband o2 Sensor and gauge
Custom Bosch 550cc High Impedance Fuel Injectors
Walbro 255hp In Tank Fuel Pump
Glowshift Trans Temp and Boost Gauges
Elecronics:
Pioneer 3300BT DVD Headunit
Rearview/nightvision Backup Camera
Cobra 75wx CB Radio
Pioneer Speakers and Tweeters
JL Audio 12" Woofer w 1000w Pioneer Amp
Suspension:
3" Leaf Springs
ARP Knuckle Studs
T100 Oil Pan
Axles:
DriveTrain:
Armor/Recovery:
Lighting:
Performance:
Elecronics:
Cobra 75wx CB Radio
Hahaha, I guess it's kinda hellaflush, no camber but the tire pokes for sure. It's super fun in the rocks, but even on the streets it's a blast, pulls as hard as a stock cummins, but goes anywhere. Next build is going to be an FJ40 Land Cruiser on 40's with a boosted K24 for the wifey.
Yes, on the current motor. I am building the other one. Stock 3.4 block, CP 9:1 Pistons, stock rods, camry crank, camry heads and cams, and a custom intake manifold. I am shooting for 450-500whp on the 37's with the built setup. It should be in the high 200's right now at 6psi.
I'd love to see the outcome of the FJ build, because I'm a huge fan.
haha thanks man
Thats awesome man! I love the 40s, such a classic. It's going to be a while before I start because I am out of time and money for a build like that right now, but I am going to start with adapting the motor to the trans and then start on a frame to keep it linked and low, but it should turn out pretty sweet. shooting for something similar to this.
I'd love to have fundage for another FJ40 build... but sadly, I don't.
Once I get the new house all setup, I may go on the hunt for an FJ though.
ezekel
18
Jul 27, 2006 11:17 AM
