Need some input settin up my civic as a dd
Old Oct 3, 2013 | 10:05 AM
Grape Ape Guy's Avatar
Default Need some input settin up my civic as a dd
I have been debugging/setting my 98 hx w 205,000mi up as a DD since I got it in june.
Things done
head rebuilt
solved water leak in trunk
valve adjustment
distributor cap
rotor
spark plugs
new radiator
oil change
fuel pressure regulator
swapped aic valve in from another car
removed lower air box (all cracked up)
new air filter
new harmonic balancer
flushed fuel filter (new one tomorrow)
general interior reassembly
I need a new lower drivers side motor mount and was thinking of using these
http://www.summitracing.com/parts/en...ic?prefilter=1
anyone have experience, i couldnt find a write up on these in faq section
I also need the sender on top of the manual transmission for speedometer.
Is there anything else pressing i should get done/troubleshoot ahead of time as winter is coming and I dont have a garage large enough to work on this in doors come cold season?
The car runs well, idles ok as long as air conditioner is turned off, belts look good and tires ok
Any input is appreciated, any brand recommendations are welcome
Thanks
Old Oct 3, 2013 | 07:44 PM
Default Re: Need some input settin up my civic as a dd
bump?
153 views no input
Old Oct 3, 2013 | 08:06 PM
crazyhouse2011's Avatar
Chillax buddy. Not sure about the mounts, but a duralast VSS (speedometer sending unit you referred to) has a lifetime warranty and i have one in my car. Works great. Very easy to swap out.
ButtersNZ
Honda CR-V & Element
Nov 17, 2015 09:38 AM
hnp5
Jan 18, 2006 02:39 PM
Moshimoto racing
Dec 28, 2005 09:30 PM
alfaaay
Mar 16, 2004 09:54 AM
alfaaay
Mar 15, 2004 11:41 PM
