99 EX stock except RDX injectors, turbo kit, chipped ECU- Las Vegas SMOG question
Old Oct 3, 2013 | 01:22 AM
k0shi's Avatar
Default 99 EX stock except RDX injectors, turbo kit, chipped ECU- Las Vegas SMOG question
Wuddup guys I currently moved to Las vegas from Hawaii (no emission laws there) and I need some help regarding smog. So first off I have a 99 EX bone stock except for RDX injectors, turbo kit, and a chipped ecu. I recently paid about $200 for smog (under the table) because I needed to get my car registered ASAP. But I was wondering if you guys know of ways I would be able to pass a smog test legally here. From what I am told by many friends they do not do a visual test so as long as my car can be hooked up and it reads a obd2 computer with no codes then I should be able to pass. I have friends who have the same car but with K swaps and they pass with no problem at all. Any help would be nice and highly appreciated because I am totally new to all this emissions stuff. THANK YOU and Mahalos!
-Koshi
Old Oct 3, 2013 | 01:30 AM
jbpnoman's Avatar
Default Re: SMOG question
A chipped ECU means you converted from OBD2B to OBD1. The smog shop can't "plug in" with an OBD harness. If you have to pass a plug-in test, you'll need to plug in the stock ECU.
Old Oct 3, 2013 | 01:31 AM
k0shi's Avatar
Yes but for me to plug in the stock ecu I would also have to switch my injectors each time i do a smog test, is that correct?
Old Oct 3, 2013 | 01:32 AM
jbpnoman's Avatar
And remove the turbo, yes.
Old Oct 3, 2013 | 01:33 AM
k0shi's Avatar
or just disconnect a charge pipe so it doesnt build boost right?
Old Oct 3, 2013 | 02:37 AM
jbpnoman's Avatar
That would work, too...if the smog mechanic is a flaming idiot.
Old Oct 3, 2013 | 05:51 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Default Re: Las Vegas - SMOG question
Like he said. The reason k swaps work is kpro allows the obd system to say all is good.
Old Oct 3, 2013 | 09:26 AM
Marvin1985's Avatar
Default Re: 99 EX stock except RDX injectors, turbo kit, chipped ECU- Las Vegas SMOG question
Better fork out another $200 under table
Old Oct 4, 2013 | 09:33 AM
k0shi's Avatar
Ok awesome thanks for your help guys!
k0shi
Oct 4, 2013 09:31 AM
teamvirus
Jan 26, 2010 08:23 PM
gurlugotmilk
Feb 6, 2009 06:29 PM
team 15
Apr 11, 2007 07:27 PM
