Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
why does hx get mpg?
Old Oct 3, 2013 | 01:00 AM
oahz's Avatar
Default why does hx get mpg?
Newbie here. It seems mpg is all I care about and airbags.
Old Oct 3, 2013 | 07:44 AM
husyk's Avatar
Default Re: why does hx get mpg?
Less features = less weight.
Longer gear ratios.
Old Oct 3, 2013 | 07:50 AM
Fliptard's Avatar
and the HX model only uses 2 cylinders when not accelerating
Old Oct 3, 2013 | 07:51 AM
likwidchz's Avatar
I also thought it did something with super lean AF ratios at cruise? like 17-18:1.... could be wrong though.
Old Oct 3, 2013 | 05:53 PM
wolfy47's Avatar
This is true in the 49 state legal HX models
Old Oct 4, 2013 | 09:55 AM
darcane's Avatar
My California model HX will enter lean burn as well. I don't believe it has been modified, but I am not the original owner, so I can't be certain.
Anyways, the reasons:
1) Taller gearing. The HX tranny has gears unique to it in the tranny and final drive. Mine runs about 2200rpm at 60mph.
2) VTEC-E. Similar to the EX, the HX gets VTEC except the lobe profiles are shaped more for economy.
3) Lean burn. Under certain conditions, the HX will operate under extremely lean conditions (Honda lean burn engines can run as high as 25:1 A/F ratios!). Wide band O2 sensor is required to manage this.
4) Weight. While not as light on features as a DX, it doesn't have many of the EX standard features. No sunroof, no power windows, no rear sway bar, and more.
Ecky
Northeast (Sales)
Sep 9, 2016 11:11 AM
Basically
Dec 7, 2005 05:45 AM
