Internal failure of SRS power supply
Recently bought a new scan tool and while checking it out I happened to enter the srs module and found a message in the code screen that said "failure of the internal power supply". At the same time I found a code in the Pgm-fi module "ELD circuit high voltage". I have since replaced the ELD (electronic load detector) and the related code has not returned. Before replacing the ELD the srs failure message was flagging as both current and intermittent, but now that I replaced the ELD the SRS failure message only flags as intermittent. I'm guessing these two issues were in some way related but I was curious to see if anyone else has had related scenarios to what I'm dealing with. One other thing to mention is that my SRS indicator on the dash does not illuminate no matter what position the key is in, I'm guessing this is because the srs module is basically inactive but just want to give all the info I have.
96civic909
Sep 11, 2012 06:06 PM
