Wiring Help
Old Oct 2, 2013 | 12:00 PM
doc500's Avatar
Default Wiring Help
I have a 1996 Accord EX F22b1. There is a connector that goes into the back of the under dash fuse panel that has the black/yellow ignition wire, yellow/black wire, white/red wire, green/black wire. Does anybody have the pinout for this connector? I have searched all over the place for a pinout.
Old Oct 2, 2013 | 06:00 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Wiring Help
Sounds like you're referring to the 5-P Blu connector. The power distribution circuit diagrams shows:
Wht/Red - Cavity 1 terminal side of connector
Blk/Yel - Cavity 2
Grn/Blk - Cavity 5
The only Yel/Blk I see for the connectors at the back of the under-dash fuse box would be at the 18-P Blu connector at cavity 18.
Old Oct 2, 2013 | 08:41 PM
doc500's Avatar
Thank you. My attempt at wire tucking the car went down the drain when money ran dry. Now I am just trying to get this thing running again.
Old Oct 3, 2013 | 08:44 AM
doc500's Avatar
It looks like, I got that right. Thank you for the help. Time to check the starter solenoid. Computer runs through the checks as it should, and check engine light turns off. I hear the fuel pump prime up. I have 12 volts to the starter, and hear a click when I turn the key to the on position. The starter does not even try to turn her over. Just one click and dead silence. Lights are bright. Battery shows full voltage. Fuses are all good.
Old Oct 6, 2013 | 04:28 AM
Lost Again's Avatar
So you have 12v on the small wire (BLK/WHT ?) on the starter solenoid when you try to start the car? If so, you have a bad starter.
You can try hitting the starter (don't kill the thing) with the handle of a large screwdriver.
Old Oct 6, 2013 | 08:35 AM
nus_dogg's Avatar
^ This.
Old Oct 11, 2013 | 12:48 PM
doc500's Avatar
I took the starter out, and put power and ground to the solenoid. Nothing.. Put power and ground to the starter motor, and the sucker revved right up. Bad solenoid it is. Will just have to get a new starter.
hatrickstu
Dec 5, 2011 05:45 AM
cold21blooded
Honda Civic (2001 - 2005)
Dec 12, 2010 04:08 PM
Emmanuel2112
Lighting
Apr 18, 2009 03:02 PM
tyrone2982
Audio / Security / Video
Jan 6, 2006 08:07 PM
delsoldude
Nov 14, 2004 09:44 AM
