Wiring help
Been fixing the wiring on my car from the previous owner and am finishing up (hopefully). Car is a 2000 GSR. Anyways I didnt note what this white wire was running to on the added components (12v constant, 12v ign, or a ground). It is spliced into the factory black/yellow wire. This black/yellow wire goes into the factory fuse block under the driver side of the dash. Anybody know what the black/yellow wire is for, and thus what the white wire would be for? The electrical components added to where this was running were for powering the fuel pumps, fan, power for logging. Fuel pumps and fans are all working through their respective relays. Typical Bosch relays with the four outer posts being used and nothing on the middle posts. I havent tried the logger yet, but i have it on a manual on/off switch so i have 12v always on to it, and then right to the pcm from the switch.
importeclipsegst
10
Nov 7, 2006 09:20 PM
